Old 12-10-2013, 04:25 PM   #1
mattcrp1
mattcrp1's Avatar
IT HAS BEGUN!!!! kinda......
Just a couple of pics of my 76 swb. I scored on a set of Trailblazer SS manifolds this weekend for $25 with down pipes. I also stuffed the eng/trans in the truck. I am using Dirtydingo slider mounts. They are the newer non welded style and I am planning on using the factory 4.8l a/c compressor in its factory location.
I decided to stuff the engine in before I did thew front suspension so I could have some weight on the springs. I had the firewall cleaned and cleared, but damaged it when I set the motor in.
mattcrp1 is offline   Reply With Quote
Old 12-10-2013, 04:26 PM   #2
mattcrp1
mattcrp1's Avatar
Re: IT HAS BEGUN!!!! kinda......
Dont mind the sledge hammer, thats my Ford tool.
Old 12-11-2013, 03:36 PM   #3
VroomVroom68
I have a grenade if you need it!
VroomVroom68 is offline   Reply With Quote
Old 12-10-2013, 06:32 PM   #4
truckdude239
truckdude239's Avatar
i dont know how different the 76 is but with the dirty dingo slider mounts ui bought they where non weld i couldn't get my compressor bracket to clear the sliders
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-10-2013, 07:09 PM   #5
mattcrp1
mattcrp1's Avatar
I actually had to un-mount the adapter from the block and as the engine came closer to the mount slip it in. It was tight going in with whole eng/trans assembly.
Old 12-11-2013, 10:51 AM   #6
solidaxel
solidaxel's Avatar
Well I guess I listened to DD salesman as he told me (before the swap) that I would have to replace the compressor as it would not fit my 78!!
So I have his upper bracket and slider motor mounts.
I do like the fact that the linkage is in the same location, and the drive shaft is in the exact location as the TH350, by looking at the seal marks on the yoke !!!
I am now looking at rebuilding the A arms while the dog house is off, what brand of bushings did you use, or were they rubber?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-11-2013, 03:35 PM   #7
mattcrp1
mattcrp1's Avatar
I did have to set the whole thing as far foward as possible to get the compressor to fit. and the intake is a few inches from the firewall. Ill try and post pics of the spacing.
Old 12-11-2013, 10:43 PM   #8
solidaxel
solidaxel's Avatar
Yes I did have to move the rear crossmember to the rear about 2 inches and re drill a few holes, and there is still clearance from the firewall
LS 3 4L70E
Old 01-06-2014, 03:06 PM   #9
mattcrp1
mattcrp1's Avatar
OK so here are a few pics of the firewall and the a/c compressor clearance with the Dirty Dingo mounts. It is a little close on the electrical connector on the a/c compressor. I am not opposed to relocating the a/c compressor to an up position, but if I can keep it low I would prefer it.
On the other hand if I relocate the compressor, I can move the engine back and close the gap on the firewall. Any thoughts anyone?.....
I am modifying the transmission crossmember now to accept the single stud type transmount.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
Old 03-21-2014, 09:19 AM   #10
solidaxel
solidaxel's Avatar
I did a final and the crossmember is 3 inches to the rear and I changed the rear mount to a 2 bolt from the stud mount on the 4L60E.
I wonder how far to the rear the engine and transmission is now from the 350/350, did this combo change the weight bias front to rear?
LS 3 4L70E
Old 03-21-2014, 12:58 PM   #11
mattcrp1
mattcrp1's Avatar
My crossmember is about 2-3inches back. I ended up removing my a/c from the stock position so i could go back further. I am eying a drive shaft from a 2004 2wd tahoe that measures 55 inches from center to center on u joint caps and the yoke sticks out 2.5" from extension housing. It will need to shortened about 2".
IG mattcrp1
Old 01-06-2014, 07:19 PM   #12
First c10
First c10's Avatar
Hello, Is this issue with the a/c the reason some people move the pedestals back to the inline 6 spot and use the forward moving mount plates? I hope you understand what i am trying to ask???
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-06-2014, 08:08 PM   #13
mattcrp1
mattcrp1's Avatar
I believe so, I hadn't heard of moving the pedistals back for the inline 6 postion. that might work too. I know some people have used this mount set up had success with it. Anyone else know?
IG mattcrp1
Old 02-24-2014, 11:54 AM   #14
mattcrp1
mattcrp1's Avatar
So I ended up having to remove the a/c and bracket as well as move the eng/trans back to gain room for the drag link and loom for the starter. It does seem a little better with the whole thing moved back. The bottom pic shows the problem and the upper shows the clearance I now have. I removed the a/c wiring and moved the loom up and secured it out of the way.
On another note, the front end is back together and down on the ground. 3 inch drop spindles and one coil cut. I threw on a fender to get a picture of what it is going to look like. I should have a pic up soon. I also got my 87 fuel injected tank as well. More to come.
IG mattcrp1
Old 03-20-2014, 10:35 PM   #15
mattcrp1
mattcrp1's Avatar
I got my 87 tank and modified a fuel level sender for an 87 to take a fuel pump from a late model fuel pump recall. Hopefully get my fuel system done this weekend. I am going with the Dorman nylon fuel line.
IG mattcrp1
Old 03-21-2014, 02:00 PM   #16
mattcrp1
mattcrp1's Avatar
Got my bargin deal trailblazer ss manifold on as well. It fits like it was made for this swap.
IG mattcrp1
Old 03-21-2014, 02:04 PM   #17
mattcrp1
mattcrp1's Avatar
Also I got my fender jambed and installed with the inner fender panel. I used a custom mixed paint aerosol can from my local Napa auto parts with a paint store in it. Cataline Blue metalic laid out nicely.
IG mattcrp1
Old 03-22-2014, 12:25 AM   #18
mattcrp1
mattcrp1's Avatar
This is the doorman tool pressing the compression fitting onto the line.
IG mattcrp1
Old 03-23-2014, 01:30 PM   #19
mattcrp1
mattcrp1's Avatar
Got the tank straps on with some roofing paper and installed the fuel lines.
IG mattcrp1
Old 03-23-2014, 01:37 PM   #20
mattcrp1
mattcrp1's Avatar
Got the engine side of the fuel line ran and secured. This part takes the longest trying not to kink the nylon is the tricky part.
IG mattcrp1
Old 03-23-2014, 07:21 PM   #21
dman1982
dman1982's Avatar
are those compression fittings on the sending unit?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-23-2014, 01:57 PM   #22
solidaxel
solidaxel's Avatar
Good idea running the nylon line in a rubber hose.
LS 3 4L70E
Old 03-23-2014, 10:03 PM   #23
mattcrp1
mattcrp1's Avatar
Yes they are. If you look at the expensive Russell AN fittings they are also compression fittings.
IG mattcrp1
Old 03-23-2014, 10:05 PM   #24
mattcrp1
mattcrp1's Avatar
I also added the clamp to be extra sure.
IG mattcrp1
Old 03-23-2014, 10:09 PM   #25
dman1982
dman1982's Avatar
I might try those man...seal good? No leaks?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
