Old 12-11-2013, 05:02 PM   #1
jimcaf
jimcaf's Avatar
2 peice driveshaft splines frozen
Getting the rear drive shaft off has been hell,,,at the splines it was frozen solid to the front drive shaft at the carrier bearing,after getting it off I soaked the female end in heavy duty degreaser over night, I got every thing cleaned and greased and it slides on about a 1/2 shy of where I need it to be to fasten it to the rear end..
anyone else run into this,,,?? thanks jim
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION
Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed
The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10
jimcaf is offline   Reply With Quote
Old 12-11-2013, 05:13 PM   #2
kwmech
Re: 2 peice driveshaft splines frozen
Occasionally, I head up the end a bit with a map gas torch. On my flatbed, I pull the driveshaft once a year if I can remember and work out the crap in the splines and put clean grease in it
Old 12-11-2013, 07:55 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: 2 peice driveshaft splines frozen
Are U putting the center carrier bearing bolts in. I leave them out for play in the shaft and then after the rear is in bolt it up.
It also helps to have the wheels off the ground to spin the rear end to help line it up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-11-2013, 09:41 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Why did you have the driveshaft out? Did you work on it? If you did it needs to be ballanced.
If the splines are frozen there is corrosion that will make the parts fit loose at ride height causing a vibration and kill carrier bearings.
If the slip is just full of old nasty grease you might be able to force it.
Be very carefull with heat it can melt the plastic coating on the slip stub and ruin it.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-11-2013, 10:05 PM   #5
Longhorn 70
Longhorn 70's Avatar
I have has good luck with removing the grease zerk and using a rubber tipped nozzle injecting air to force it apart.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-12-2013, 12:44 AM   #6
BigRed76
BigRed76's Avatar
What do you mean by splines?? My 2 piece drive shaft has no splines, just two shafts attached in the middle at the carrier bearing...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 12-12-2013, 10:39 AM   #7
brad_man_72
the boat guy
A lot of old gm cars and trucks with trailing arms didn't have a slip yoke because the rear axle didn't move foreward and back very much with suspension travel.
Everything more modern and a few 67-72s have a slip yoke in the center of their 2 piece shafts.
Old 12-12-2013, 10:56 AM   #8
jimcaf
jimcaf's Avatar
Yep,mine has a splined yoke,the last time I had it out I jambed it in this time around I put new U joints and dont want to force it on where its binding.Thanks for the posts ,,,jim
Old 12-12-2013, 09:52 AM   #9
Longhorn 70
There is a splined slip joint there.
Old 12-12-2013, 12:55 PM   #10
Longhorn 70
try the grease zerk thing if your slip yoke has one.
Pump a few shots of HD grease in.
Remove the zerk
Put a rubber tipped blow nozzle on the hole
Let the air go.....It pushed mine out.
No Prying needed.
Old 12-12-2013, 01:28 PM   #11
brad_man_72
the boat guy
Make sure to mark everything, flipping stuff around will really mess up the ballance. Even moreso than swapping ujoints. Especially if you use house brand or precision instead of a quality spicer or neapco joint.
