Old 12-12-2013, 06:56 PM   #1
BigCountryx
BigCountryx's Avatar
What diameter clutch?
My clutch on my '70 is slipping (250/3 speed). All the part houses list a 10" and an 11". Which do I need and how would I check to see what's in there now? Need to get one ordered soon.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 12-12-2013, 07:08 PM   #2
killerpanel
Re: What diameter clutch?
The only sure way to know, is to pull it out and measure the disc. From what I recall, most the trucks used the larger clutch. I'll say i've never seen the smaller in a truck.
killerpanel is offline   Reply With Quote
Old 12-12-2013, 07:15 PM   #3
BigCountryx
Not exactly what I wanted to hear but definitely more info than I had, thanks. Unless someone else has a different opinion I'll order the 11" and roll the dice that it's the one I need. Thanks
Old 12-12-2013, 07:19 PM   #4
jhama78
jhama78's Avatar
Fwiw my 67 has an 11" clutch with a 250 and a 3 speed.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 12-12-2013, 07:38 PM   #5
John Pasinski
John Pasinski's Avatar
11" clutch, BB are 12, & 13".
IMHO......Aways resurface the flywheel, and pressure plate whenever changing the clutch. Like a new relationship, everything will mate up and get along much better when you complete those steps. Make sure to use the spline that should come w/ the new clutch so the disc and pressure plate are aligned correctly. If the trans will not slide in relatively easy, DO NOT force it, and NEVER EVER draw it to the bell housing with the bolts. If you have to do that, someting's wrong. Lastly, don't ask me how I know.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 12-12-2013, 08:23 PM   #6
BigCountryx
Great info. Preciate it guys, I ordered a new 11" clutch set and flywheel. Figured it be the safest bet.
Old 12-12-2013, 11:37 PM   #7
hamjet
hamjet's Avatar
As long as you have it out it wouldn't hurt to change the input shaft pilot bushing in the end of the crank. theyr'e cheap and easy to remove. fill it with grease and find a dowel the size of the hole and hit it with a hammer. it will come out.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-13-2013, 09:05 AM   #8
BigCountryx
The set comes with the clutch, pressure plate, throw out bearing and pilot bearing I believe.
Old 12-13-2013, 09:45 AM   #9
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
If you currently have a 10" clutch, then you can only replace with a 10" due to the flywheel bolt circle. If you have an 11", then you can put an 11" or a 12".
The two ways to know whats in there is if you have something like HD Clutch on your spid, then you have an 11".
Be sure to get your flywheel reground.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 12-13-2013, 04:05 PM   #10
BigCountryx
Thanks. Nothing like that on the SPID, mine is almost blank lol. I ordered a new flywheel too.
