Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-17-2013, 01:20 AM   #1
Chvy2NV
LQ9 misfire.. No codes or CEL
What's up guys. I have a 07 NNBS with a Vortec MAX 6.0L and I seem to have a misfire at idle or reverse. Once the truck is going. It seems to be just fine. Ive had the truck 2-3 months now and Ive read endless threads and can't seem to pinpoint what could be causing this. I've had the truck plugged into a code scanner and have gotten 0 codes or CEL 's.
I called friend of mine which is a service manger at a local Chevy dealer and he says that it's completely normal. This is not what I wanted to hear... After trying to convince myself that this is "normal" for the past few weeks I took it to another friend of mine which has had his share of GM vehicles.
After sitting in the truck for 30 sec. He says to me. This **** is broken... There has to be a problem here. There's no way this drove off the lot like this. Which brings me to writing this.
What do you guys suggest I try next?
Chvy2NV is offline   Reply With Quote
Old 12-18-2013, 07:45 AM   #2
GMCJOE
GMCJOE's Avatar
Re: LQ9 misfire.. No codes or CEL
Does it sound like it is misfiring? Or does it feel like it is by sitting in the cab? I thought mine was too, it felt like it had a ruff idle sitting still. I popped the hood and noticed my harmonic balancer wobbling a bit. Dealer also told me it was normal. You could clearly see the idler jumping around correcting it. Idiots!
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 12-18-2013, 09:10 PM   #3
Chvy2NV
I haven't really heard it. It's more of a feeling it thing. Truck just shakes kinda thing and the gauge fluctuates.
Old 12-18-2013, 09:22 PM   #4
GMCJOE
GMCJOE's Avatar
Samething mine is doing. Start it up, pop the hood and look at the harmonic balancer. Probably has a slight wobble to it, and the tensioner pully will be jumping. My balancer was new on the motor when I bought the truck, been off 3 times since for warranty work. So, I got a defective one I need to replace. Update to let me know if you got the same issue. Mine is on a 5.3.
Joseph
Joe's 69 GMC
Old 12-25-2013, 04:25 PM   #5
buddy_1
buddy_1's Avatar
What is it idling at RPM wise? How many miles on it?
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 12-26-2013, 09:21 PM   #6
Chvy2NV
Truck has 100k. Idle is at 500 once it warms up. But initially it's pretty iratic. Which the more I read up on it the more others say it's completely normal. They say these motors make great power but the idle is crappy.
Old 12-26-2013, 09:32 PM   #7
buddy_1
buddy_1's Avatar
Couple of things to check. First, clean the throttle body real good. It should idle a little higher than that. If its really carboned up you will probably have to have the idle relearned afterwards or it'll idle too high. The other thing to check is the condition of the engine mounts. They are bad about collapsing and grounding out thus causing a rough idle that some think is a misfire.
Old 12-28-2013, 01:20 AM   #8
lowridergmc
lowridergmc's Avatar
its normal.i remember seeing a a bulletin on it at one time.
lowridergmc is offline   Reply With Quote
Old 12-28-2013, 10:21 AM   #9
Special-Ed
Special-Ed's Avatar
Motor mounts could cause this symptom as well.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 12-29-2013, 03:36 PM   #10
Chvy2NV
Mounts are ok.
Old 12-31-2013, 05:02 PM   #11
bighaas79
I was told in a GM class that it is a normal running condition because supposedly the factory programming actually has these motors running overly lean at idle to help to pass emmisions testing. Truth to that or not... not sure, but I know GM did alot of programming tricks with the 6.0's as far as torque management, and what not to make transmissions survive behind the amount of power these engines can put out. If they did infact program idle lean strategies for emissions it really wouldn't surprise me.
bighaas79 is offline   Reply With Quote
Old 01-01-2014, 12:46 PM   #12
Chvy2NV
Would a tune fix this issue? Like a black bear tune?
Old 01-02-2014, 11:23 AM   #13
bighaas79
A tune would probably help across the board so I don't see that it would hurt to try.
