Old 12-17-2013, 07:08 PM   #1
Jahloha
Jahloha's Avatar
Final Frame Paint Plan, Input Please
TEAM:
I would like to try Rustoleum for my frame paint and will be brushing on all paints. Please take into consideration this will be a DD and also trying to stay on budget.
Here is my plan:
FRAME PREP
I have nearly bare metal from the firewall forward, with a few places of light surface rust (example of frame condition):
Name:  After Wire Brush.jpg
PRIMER PLAN
I plan on using this Rustoleum product for a primer:
http://www.rustoleum.com/product-cat...l-primer-spray
TOP COAT PLAN
For the top coat I am planning on this Rustoleum product:
http://www.rustoleum.com/en/product-...tective-enamel
Question:
I want to use a hardener to assist the top coat in curing and also add to its durability; does hardener do that? If so, can I add hardener and brush the top coat on?
What are your overall thoughts of this plan?
Mahalo
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-17-2013, 08:01 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Final Frame Paint Plan, Input Please
I would highly recommend adding hardner to Rustoleum. It will make dry time to handle, drop from from a week, to a few hours. It also makes it much more durable. Spraying would be the best way to apply, but brushing will work in a pinch.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-17-2013, 08:03 PM   #3
Jahloha
Jahloha's Avatar
Good to know I am thinking on the right track.
Are all hardeners created equal? Or should I stick to a certain brand?
I have never used hardener in a paint before.
-JASON
Old 12-17-2013, 09:47 PM   #4
turp mcspray
I like Rustoleum Satin black for brackets, pulleys, inner fenders,etc. My local TSC store has their brand, but I haven't tried it to compare how it looks. They have "Matte Black" which I don't know if it looks like satin, or flat. I buy their hardner, and use it in the Rustoleum. I think it is about $14 for a 1/2 pint.
Turp Mcspray
Old 12-17-2013, 09:58 PM   #5
HotRod C/10
HotRod C/10's Avatar
what brand is the hardner you use from TSC?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-18-2013, 06:51 PM   #6
Fitz
Rust-oleum industrial acrylic hardener.
Fitz is offline   Reply With Quote
Old 12-19-2013, 10:54 AM   #7
turp mcspray
I don't remember the name. Seems like it was a green label.
Turp Mcspray
Old 12-19-2013, 01:41 PM   #8
54blackhornet
54blackhornet's Avatar
I contact a firm in Eastern Oregon "Baretto MFG" quoted me $25.00 a wheel to blast and power coat, and only $50.00 to blast my 71 LWB K-10 frame . Sounds like a better deal then some of you guy's get ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-19-2013, 06:35 PM   #9
Jahloha
Jahloha's Avatar
Originally Posted by Tinkermc View Post
with any paint it is a good idea to use their material all the way through the job.
For sure.
That is absolutely a good deal to get a frame blasted. Non of us would wire wheel the frame at a cost like that.
-JASON
Old 12-18-2013, 07:34 PM   #10
Tinkermc
Tinkermc is offline   Reply With Quote
