12-18-2013, 02:58 PM | #1 |
How much z
I'm wanting to sfbd my 83 c10. I have the truck laying crossmember in the shop right now and with welding a piece of 2x4 to the top inside of the frame, my measurements are showing in going to need to z 4".every where I have read people are doing 3" z. Am I doing something wrong or is it going to change that much when I do my cut.
85 swb c10 6/6 drop 83 c10 bagged and sfbd project |
12-18-2013, 08:07 PM | #2 |
Re: How much z
I've heard 2 inches max if your z'ing the frame. I'm just shooting from the hip, I'll look up the thread where I read that and post it for you.
Scott |
12-18-2013, 08:13 PM | #3 |
Re: How much z
This is chevyrestoguy's build thread, he detailed z'ing the frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=446527
Scott |
12-18-2013, 09:06 PM | #4 |
Re: How much z
I measured mine out though it is a C20. I need 2'' to lay flat and 4'' to do the sfdb with 2x4. Luifer and has two half tons and did 3'' (check his build thread on here). I would go with my own measurements on my own frame.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
12-19-2013, 12:39 AM | #5 |
Re: How much z
i read through luifer's thread, and it worked for him. but i got the same measurements as you tiny.
12-19-2013, 01:03 AM | #6 |
Re: How much z
12-19-2013, 09:16 PM | #7 |
Re: How much z
i cut it today, 3 will work. your c20 frame is the same height as a c10. i couldnt bring myself to do 4 that was way to much.
12-19-2013, 09:18 PM | #8 |
Re: How much z
So where are our 4 inch measurements coming from?? lol
12-19-2013, 09:23 PM | #9 |
Re: How much z
i have no clue, i had my springs out and crossmember on the ground. and measured from the bottom of the piece of 2x4 to the ground was 4". if it didnt lay out at 3" i wasnt cutting the bottom of the frame off but it did.
12-19-2013, 09:28 PM | #10 |
Re: How much z
Steel 2x4 or wood? Just cause a wood 2x4 isn't actually 2''x4''
12-19-2013, 10:46 PM | #11 |
Re: How much z
steel, yea 3.5" still wouldnt make up for my messed up math
12-20-2013, 10:59 AM | #12 |
Square
Re: How much z
I think 4 inches was the amount people did that wanted to lay rocker
3 inches is the normal z If you plan of doing a z, Id like to offer a better plan of attack: 2 inch crossmember pancake, 1inch Z (straight up and down) Porterbuilt narrowed and forward control arms doing this instead of a full z will be so much better. you will keep your engine way lower in your engine bay, your driveshaft will clear your cab much better, and you will have less camber/bumpsteer. this is just what I would have done if I wasnt running dropmembers.
Squarebody Syndicate |
12-20-2013, 12:20 PM | #13 | |
Re: How much z
12-20-2013, 12:31 PM | #14 |
Square
Re: How much z
The 2x4 is to box the frame where the bottom is cut off to lay rocker. When you cut the bottom of the frame off you are now making the front crossmember having to come up 1 more inch so that the frame is again the lowest part of the truck. A 2 inch pancake is the normal amount people do. It also seems to be the most you can do an keep the steering box on place and working properly. So you get the last one inch by z'ing the frame.
12-20-2013, 12:45 PM | #15 |
Re: How much z
http://www.captkaoscustoms.com/chopcross.html
I am pretty sure you cant do 2 inches. I started sectioning one after spending a ton of time reading on here. I started cutting mine for 1.25 inches after seeing a bunch of steering issues. I never finished it and am going to do a Z instead. Edit* I have see your build tread (nice trucks btw) but I meant the most you can section while maintain factory steering.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by tinydb84; 12-20-2013 at 12:53 PM. |
12-20-2013, 01:04 PM | #16 |
67-72 parts collector,…
Re: How much z
I think you two need to compare apples to apples.
1.25"-1.5" sectioned crossmember with the steering box in the stock location on the frame should work fine. I think there have been some 2" "pancaked"/sectioned crossmembers,... but the steering box is also raised 2" and the frame is notched for tie rod clearance. (like Dino has been doing lately)
12-20-2013, 01:07 PM | #17 |
Re: How much z
^^^agreed. My 66 is raised 2 inches but the frame is notched and the steering box was moved up 2 inches as well.
12-20-2013, 02:22 PM | #18 |
Square
Re: How much z
Yeah I was basing this off of Dino's trucks. Those are the only way I had seen it done. You could do 1.5 pancake and 1.5 z to maybe help. All I'm really getting at is to try to do the smallest z possible.
12-21-2013, 03:08 AM | #19 |
Re: How much z
I agree, Broey. When you start going over 2" on a Z, you open up a can of worms that gets even more complicated the higher you go. I went with a 2", and the job was pretty simple. The part(s) that required the most work was everything else that tied to the frame, like the inner fenders, the engine mounts, steering linkage, and such.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
