07-16-2003, 08:14 PM | #1 |
taking out a windshield
How do you remove a windshield out of our trucks with the chrome trim in the gasket?
07-16-2003, 08:21 PM | #2 |
its all about the +6 inches
BRICK
Are you removing it to replace the glass?
If so kill the glass. If you are replacing the seal, it can be sacrificed pretty easily too. |
07-16-2003, 08:25 PM | #3 |
lol longhorn. My track record on removing windshields wont require a brick for me. I'm taking one out of a old parts truck to save back.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
07-16-2003, 08:27 PM | #4 |
I'd cut the rubber. It isn't worth saving anyways.
07-16-2003, 08:28 PM | #5 |
huh?
Do what Andy says. Cut the rubber (cut the hell out of it, it's a POS anyways after it's been used), they're fairly easy to remove with the rubber cut out.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-16-2003, 09:08 PM | #6 |
Process= with a razor box cutter and some heavy gloves, cut the inside of the windshield gasket being careful not to let the cutter get away from you. The rubber will be hard and soft in places so be careful. Make a circle cut around the windshield pulling the excess rubber as you go, then push the window forward till it pops loose. Usually the upper corners are the toughest to get out as they were put in with some caulking from the factory. Don't bang the window unless youare trashing it as old glass is more fragile then the new stuff. Good luck--Huck
PS Much easier to get out then to get in!! |
07-16-2003, 09:12 PM | #7 |
Yep - do what they said.
Cut the gasket on the inside. Then you get in the cab and push out with your feet. Have a buddy on the outside to catch the glass. |
07-16-2003, 10:00 PM | #8 |
call the glass company to come do it that way if it breaks they get to buy you a new one
07-16-2003, 10:12 PM | #9 |
Thanks guys I did what you all said and just cut the gasket, only I didn't know and took the stainless trim out and cut it on the outside. It came out easy.
