![]() Join Date: Dec 2012
'59 Gmc Hood emblem
Bad news, When I went for a ride in my pasture.I hit a bump and the Hood Emblem came off and got ran over.I am a loss for words, beyond mad.I hope it can be fixed (welded or whatever)
Wasn't too bright on my part, going to see if I can get it fixed It has a lot of senti mental value, that is why I want to fix it so bad
1971 GMC Sierra 1959 GMC 100 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: '59 Gmc Hood emblem
Thats not Chrome ??
It looks like its painted
Well I guess no one thinks it is savable...Ugh
It CAN be repaired !!
How though?
It seems nearly impossible
and a few others
You could probably put masking tape on the front side, mix up some two part epoxy, apply to back side, remove the tape which kept the epoxy from oozing through to the front, re-install. I'm not familiar with the 59's trim, is this held on with pal-nuts? If so, just don't over-tighten or it will break again.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
JB Weld, with a little thin reinforcing in the recess on the back is worth a try. Very good welder could possibly braze it, but a lot of times the pot metal just melts away under heat. Sounds like first order of business is to take some time to check nuts and bolts for tightness to see what else the PO did not tighten down like cab, bed, fenders, mounts, etc.
It just tore me to pieces to see what happened to it, *sigh*. I actually have some Strong JB Weld some where that I bought for my '71, I will see what I can do
I'll need to get new Bed Fender bolts, the Frame to fender things aren't in place.I just parked it up in my barn because I was so damn pissed off at what had happened.Getting some money for Christmas and if I can get enough I'll just save up to get some important Patch panels
1971 GMC Sierra 1959 GMC 100 Last edited by SCHRUMGMC; 12-22-2013 at 04:41 PM. |
Where can I buy that stuff locally ?
Local to you I have no idea ? But it works Great
I just want it to look like it was never broken, I'll see what I can do
