Old 12-23-2013, 09:46 AM   #1
Matt Cramer
Steam line to stock radiator fitting - any easy options?
I've got just a few things left to do to get my swap running. One is plumbing up the steam line. I was thinking of trying to run it to the 3/4" fitting on the stock radiator. Is there any fitting that's an easy way to adapt this - maybe one that screws into it, or brazes on? How did you guys running stock radiators handle the steam line (and if it wasn't plumbed to the 3/4" fitting, what did you use to block that off)?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 12-23-2013, 10:22 AM   #2
Clyde65
Clyde65's Avatar
Re: Steam line to stock radiator fitting - any easy options?
I used an adapter from here
http://www.jagsthatrun.com/Cooling-S...rts_Order.html
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-23-2013, 11:41 AM   #3
Billett
Billett's Avatar
Mine rad came with a plug, I ran my steam vent to the top of the water pump. Just drill and tap.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 12-23-2013, 12:02 PM   #4
ls1nova71
ls1nova71's Avatar
I used my original 4 core, just took it to the radiator shop and had a brass fitting brazed in the tank. I wanted to have it boiled out anyway, so it was a two birds with one stone kind of deal.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-23-2013, 08:20 PM   #5
71chevystep4x4
71chevystep4x4's Avatar
I ran mine to a T fitting on the heater hose, didn't want to go too in depth with the radiator.
71chevystep4x4 is offline   Reply With Quote
Old 12-23-2013, 10:48 PM   #6
TR65
TR65's Avatar
I used an AN bulkhead fitting and an o-ring washer. Just drill a hole in the tank near the filler cap so you can reach in and tighten the bulkhead nut. No trouble after a couple of years.
This follows GM's recommendation to plumb the steam line to the highest point in the cooling system.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 12-24-2013, 01:03 PM   #7
Blackpony
Blackpony's Avatar
I went to oreillys and bought a t fitting and attached it to the heater hose coming off the water pump.
Blackpony is offline   Reply With Quote
Old 12-24-2013, 11:06 PM   #8
Jon01
Jon01's Avatar
I drill and tap the pad on the top of the water pump, insert a small hose barb and run the line there. I've done it on several swaps without issue.
Jon01 is offline   Reply With Quote
Old 12-26-2013, 04:40 PM   #9
Blackpony
Blackpony's Avatar
^^ that's a good idea! I may switch mine as the t fitting I am using is a 3/8 barb so I am having to use a reducer since the crossover tube is 1/4. Bugs me haha
