12-25-2013, 10:44 AM | #1 |
Spark plug wires
I have a 350 motor, Headers & HEI. I have yet to find wires that are the right length for all the plugs. Most sets are for the factory setup. I don't want to cut, shorten, fit or what ever. I have went to a few stores to ask if I could buy single wires with a certain length, no luck. Any suggestion out there ? Would like to see some pictures how nice your wires look with headers.
12-25-2013, 10:52 AM | #2 | |
The Older Generation
Re: Spark plug wires
Read through this thread and see if it helps.... (read the whole thread) http://67-72chevytrucks.com/vboard/s...d.php?t=387485 If you type the words "plug wires with headers" into the GOOGLE search box at the top of this page, click on the circle in front of "67-72chevytrucks.com" and click on the GOOGLE button you will find lots of threads on the subject. Just make sure the thread you are looking at refers to your style of truck. (Hits will include all years) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-25-2013 at 11:00 AM. |
12-25-2013, 11:03 AM | #3 |
Best thing to do is suck it up and buy the "cut to fit" kit. Otherwise, nothing ever fits right.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
12-25-2013, 11:18 AM | #4 | |
Active Member
If you go this route be sure and get the proper tool to crimp the ends. Some crimping tools I've seen are less then $25 but there are better ones for less than $50. It's the way to go for a custom fit.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
12-25-2013, 11:28 AM | #5 | |
Edit: the PO put on a decent looking set of Accel wires. With the 65k HEI the start up and performance of the Taylor wires was very noticeable.
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 12-25-2013 at 12:18 PM. |
12-25-2013, 11:38 AM | #6 |
Motor is looking good !!!!!
12-25-2013, 12:11 PM | #7 |
I've used Taylor wires on both of my Cougars and am really happy with the results. Summit has them for a pretty good price and they make lots of different colors from black to bright purple. This set has been on my modified Cougar for 16 years now.
http://67-72chevytrucks.com/vboard/a...1&d=1387987575
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
12-25-2013, 12:22 PM | #8 |
Don't forget spending the extra bones for wire looms if you customize to fit. Sorta a pain at first but when you are done they stay neat and trouble free from then on.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-25-2013, 12:43 PM | #9 |
I went the Taylor cable, "Cut to Fit" route the last time I did my wires. Worked out pretty well but for some reason one of the boots burned after about a year. I just ordered a set of Moroso Mag-Tune wires. The distributor boots
come attached but you have to cut each wire to length and install the plug boot. I think this approach will work better because I can choose the type (Angle) of each plug boot and apply markers. All the boots are silicone so heat won't be so much of a problem and they're less expensive than Taylors. |
12-25-2013, 12:53 PM | #10 |
Old member
On my old 305 TPI motor I always asked for Camaro wires they seem to do pretty good. I always got the straight boot ones for HEI.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-25-2013, 01:54 PM | #11 |
I ended up using the Taylor (cut to fit) wires. I used a friends crimper and i think they look good.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
12-25-2013, 03:34 PM | #12 |
search a site like summitracing.com - can find all types of plug wires, including individuals. when running headers I found Accel Extreme 9000 Ceramic Spark Plug Wire Set to work good.
12-25-2013, 04:29 PM | #13 |
Look at www.magnecore.com. They are not cheep but they may fit your need.
Seems like the link is messing up, just type in magnecore wires. try www.magnecor.com |
12-25-2013, 06:30 PM | #14 |
Once you get the hang of cutting and crimping your own wires you won't want to use anything else.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
12-27-2013, 05:22 PM | #15 |
taylor cut to fit
Fuzzy |
01-01-2014, 05:22 PM | #16 |
took the plunge and cut my own. Bought a good crimper. Worked like a charm
Figure out what you want--then figure out what you are willing to give up to get it. |
01-01-2014, 07:57 PM | #17 |
Wasn't so bad after all....came out looking great!
1970 C10 Short Stepper with 71/72 front clip. |
01-01-2014, 05:24 PM | #18 |
What brand wires did you buy?
Paul
01-01-2014, 05:51 PM | #19 |
bulk Taylor SPIRO PRO 8MM silicone..I believe from JEGS. I also ordered the 180 degree spark plug connectors (black) as well as the distributor jacks.
1 1 555-80570 CRIMPER W/SPARK PLUG DIE 41.99 41.99 1 1 895-46003 SPARK PLUG WIRE CONNECTOR 21.99 21.99 1 1 895-46057 90? SOCKET BOOT/TERMINALS 19.99 Loom came from Summitt. Lou
01-01-2014, 06:11 PM | #20 |
Looks great! Nice and neat.
Paul
01-01-2014, 08:29 PM | #21 |
Looks great!! Now I know where my gift card is going to.
I put mine under the headers and haven't had any issues. It just doesn't look....right.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-02-2014, 11:18 AM | #22 |
I like them under the header. Depending one the headers it helps to keep from burning the wire. Also makes pulling the valve cover easy.
01-02-2014, 11:34 AM | #23 |
I run all mine in the Corvette position. They come up under the headers and alongside the block. GM made some nice cheap wire holders that bolt to the block that I use.
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
01-02-2014, 12:13 PM | #24 |
I've been through this dilemma a few times before and I have to agree. The best way to get a clean fitting set of wires is to cut to length. A few months ago I decided to bite the bullet and invest in a good wire crimper. I got this one.
Amazon.com: ACCEL 170036 Wire Crimp Tool:... I also got a set of Moroso 8mm cut to fit wires and last Saturday I finally built up my first set for the C10. It was actually quite a bit of fun building them with the proper tool. From now on, this is the only way I will ever do it. |
Tags |
step sides for ever |
