Old 12-28-2013, 11:37 PM   #1
70CHEVYBB
70CHEVYBB's Avatar
two piece or one piece drive shaft
I have a lwb 70 and was wondering if I should just keep the two piece drive shaft or put in a one piece shaft. I don't really haul anything so clearance at the trailing arm member is no problem. I am reinstalling myhigh horse big block and have heard the carrier bearing is a week link. any thoughts on this would be great.
70CHEVYBB is offline   Reply With Quote
Old 12-29-2013, 12:01 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: two piece or one piece drive shaft
People not having their driveshafts properly ballanced kills carrier bearings.
Theirs a dozen wrong ways to rebuild a driveshaft but even when everything is done right the shaft still needs to be ballanced.
A one piece shaft is far less sensitive to ballance issues, you can ruin 2 or 3 tailshafts before you figure out the driveshaft is the problem.
There's plenty of advantages to a 2 piece driveline, simplicity isn't one of them.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-12-2014, 03:08 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
X2i would like to add "if it aint broke dont fix it!"
WIDESIDE72 is offline   Reply With Quote
Old 12-29-2013, 06:52 PM   #4
bigmac73
bigmac73's Avatar
subscribing, and interested
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-29-2013, 07:12 PM   #5
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
If I were running any horsepower I'd probably opt for a one piece driveline mainly for less rotating mass and because of the way you can move the joint around at the squishy stock style carrier bearing. I have been the demise of plenty of rear tires with a two piece driveline without any trouble either way but I would imagine with enough power and traction you could make the stock carrier isolator oscillate but that's just my opinion. I have never seen it happen.
Oldtruckfanatic is offline   Reply With Quote
Old 12-29-2013, 07:22 PM   #6
tlcrz1972
tlcrz1972's Avatar
First off you can not run a one piece driveshaft on a longed with an unmodified bulkhead (trailing arm attach crossmember). The drive shaft will hit the lower portion of the bulkhead where the carrier bearing mounts. The reason for it hitting is that the bulkhead is further aft of the transmission (than what a shortbed is) and the line of sight from the trans output shaft to the pinion will allow it to hit the bottom of the bulkhead.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 12-29-2013, 07:16 PM   #7
68shortfleet
When I had a one piece driveline built for my SWB, I had to have tube with an extra thick wall for the length that I needed. The shop said I was right at the limit for length. Who know's if they were just playing it safe though, so as not to be a vibration/warranty problem in the future.
So, I am betting that a one piece is going to be too long for a 2wd lwb.
68shortfleet is offline   Reply With Quote
Old 12-29-2013, 10:38 PM   #8
brad_man_72
the boat guy
Extra thick would make the "jump rope" problem worse. You want a thin large diameter shaft for long lengths. This is why a lot of new trucks have 5" thin wall aluminum shafts that bend if you look at them wrong.
Rotating mass "polar moment of inertia" between a 2 piece shaft and one piece shaft would be nearly the same due to the larger diameter shaft required for a one piece shaft.
I've built dozens of 3.5" diameter one piece driveshafts for longbed 67-72s with no clearance issues. Most that I know of were lowered.
Old 12-29-2013, 07:27 PM   #9
Oldtruckfanatic
Truck junkie
In reply to 68 shortfleet that's weird. When I was looking for a driveline for my swb conversion I found several Chevy vans in the yard with long drivelines. Unfortunately every one of them was destroyed from being lifted by a forklift. I opted to just have the two piece shortened at that point but that's an interesting thing I'd like to know for my own builds. Also I watch street outlaws quite a bit and I'd love to know what the farmtruck has for a driveshaft.
Old 12-29-2013, 07:41 PM   #10
tlcrz1972
tlcrz1972's Avatar
I'm not an expert on vans but I believe those were all leaf springs rear suspensions.
Old 12-29-2013, 08:42 PM   #11
Oldtruckfanatic
Truck junkie
It doesn't matter leaf or trailing arm the truck still has the same crossmember it just doesn't have the trailing arm brackets on it. Even the holes for the brackets are still there so if it's a clearance problem it exists either way and if a certain length is too long for balance or strength issues it would apply either way. Shortfleet68 was simply stating that his driveline shop said the length he had made which I bet was about 59-60" center of the u joints was right at the limit for a one piece driveline. He didn't say at the limit for trailing arm or leaf springs. His 68 is likely trailing arm. The only difference I would think would matter as far as the two suspensions go is that without the shocks to limit the travel the trailing arms would allow more length change but with the shocks its about the same. I have built several trucks in both configurations and seen both kinds of drivelines in both wheelbases.at any rate not meaning to get off the topic. He just said the length was at the limit but I have seen plenty of longer one piece drivelines and I'm hoping that info.helps the original poster.
Old 12-29-2013, 09:26 PM   #12
70CHEVYBB
70CHEVYBB's Avatar
I think I will install new u-joints (already have a new carrier bearing) and send it to get it balanced
Old 12-29-2013, 09:53 PM   #13
Keith Seymore
Keith Seymore's Avatar
This is why some trucks get a one piece shaft and a similar looking truck might have a two piece shaft:
Originally Posted by Keith Seymore View Post
It has to do with propshaft (aka "driveshaft") critical speed.
What you guys might be missing is that propshaft critical speed not just based on wheelbase but is also based on trans type (length), rear axle ratio, tire size, and engine type (larger engines allowing a higher top speed) AND/OR any strange resonances in that particular combination (camping out on that resonance will break the trans/transfer case tailshaft housing).
So - a long wheelbase truck with a low (numerical) rear axle ratio spins the shaft slower and might get a one piece, but an otherwise comparable truck with a high rear axle ratio might get a two piece.
One other comment - critical speed is not directly related to balance, but rigidity. When the shaft exceeds it's critical speed it begins to bow in the middle and swing like a jump rope. Hence the disturbance and durability concerns.
You can get around it by going to a larger diameter steel tube - or more expensive alternative materials like aluminum, carbon fiber or "metal matrix" (an aluminum/carbon wrap).
By the way, I hate the complexity and mass of a two piece setup and go out of my way to order my trucks such that they get a one piece shaft.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-01-2014, 01:03 PM   #14
Treetop839
Treetop839's Avatar
I was going to put a one piece shaft in my 70 lwb with a stock 1994 350/700R4 and stock stance. I have a friend that has three lwb trucks and runs a one piece shaft in them with no problems. He is using a steel shaft that has been cut down to the length needed, I don't know the diameter but they are a small diameter. I had a shaft out of a newer body style truck built and am going to go back to the 2piece. The new one is the aluminum and carbon fiber 4" shaft and it does not leave much room on side clearance through the cross member. With out the body on the frame I cannot bolt it to the rearend for it hitting the bottom of the crossmember. Drive shaft guy told me if the shaft hits the side of the crossmember it will cut it in two. There are a lot of people on here with more experience than me on this, just thought id let you know about my $150 lesson. Good luck!
Treetop839 is offline   Reply With Quote
Old 01-01-2014, 03:14 PM   #15
burnin oil
You could always just notch the bottom of the crossmember for clerence. If you think it needs support for rigidity some more metal could be added a little lower on the cross member. I love metal because of welders.
burnin oil is offline   Reply With Quote
Old 01-11-2014, 11:04 PM   #16
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I would like to know the size of the tube he used and pics would be awesome.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-01-2014, 03:07 PM   #17
burnin oil
5 foot is the theoetical max length for a drive shaft but that can be exceded without issue. U joint operating angle is the issue. Much more so than shaft balance! To much angle at one end will cause vibration and short joint and bearing life. There is nothing wrong with a thick tube driveshaft and rotational mass. A standard flywheel is around 44 pounds vs 5-10 for a flexplate. I know where you are going with this but steel wheels vs alum will have a bigger inertia difference. Search on roadranger.com for the Eaton driveline manual, around ten pages, and it will teach you more than you ever wanted to know about 1,2, 3, or four piece drive shafts, phasing, u joint angles, and shaft speed. A one piece shaft will fit on some trucks. I put a 1 piece in the rear of my 60 long bed without issues. If you need a 2 piece shaft to keep everything working correctly look into upgrading the carrier bearing. Medium duty trucks have 20 foot of driveshaft under them with alot more torque and low gears. How many of those do you see on the side of the road with the driveshafts hanging down. I have seen more pretzeled semi shafts from 2000 ftlbs of torque.
Old 01-01-2014, 05:57 PM   #18
brad_man_72
the boat guy
A lot of what you said is true for large trucks, their driveshafts don't spin as fast as a passenger car. This is becoming less true with od transmissions, this is why we are seeing more rpl and spl style driveshafts that spin fast enough fo ballance to become an issue.
I've seen dozens of big truck shafts that weren't properly ballanced beat a carrier bearing to death very quickly.
I've built thousands of driveshafts, hundreds of them being for limos, so were talking 3,4,5 piece drivelines. Ballance is absolutly critical, driveline angles are very important also in a passenger car application.
I've seen people break 3 transfer cases, angle wasn't the problem, the shaft wasn't ballanced.
Dozens of cars with trashed tailhousings, again no angle problems, just ballance.
Old 01-01-2014, 07:32 PM   #19
burnin oil
Even with tall tires I bet the medium duties are running similiar driveshaft speeds considering rear ratios in the 6 and 7s being normal. Some less and some more gearing.
If someone breaks 3 transfer cases I would be looking for more than a driveshaft balance issue. I can see it contributing to the problem but not enough to kill it. I have seen a few that were bad enough to feel like the truck was bouncing and not blow apart. I would suspect the shaft was to long, loose or bad/weak mount, or possibly a pinion angle issue under acceleration. The 2 biggest killers of tcases I have seen is the driveshaft bottoming out or excessive flex of the case from torque.
I am not doughting your expertise in driveshafts and think balancing is important but is only part of the equation
Old 01-01-2014, 06:36 PM   #20
slomotion
Old Duffer
slomotion's Avatar
You guys are talking way over my head, but I suspect GM thought out the drive shaft issue before they put millions of them together. I've never had to deal with a modified truck with so much torque that I was concerned with a two-piece shaft. I have installed heavier carrier bearings though just for peace of mind.
One thing I never did quite understand was why, if both shafts of a two-piece drive shaft was balanced independently was phasing so critical? I put a driveshaft together one time with the second shaft 180 deg. out, and it didn't take long to develop a vibration that rattled my teeth! I got home, dropped the shaft(s), re-phased the shafts, put it all back up, and everything was smooth as silk. Now I mark the yokes with a punch just to be sure, because chalk and crayon can and will come off!
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 01-01-2014, 07:41 PM   #21
burnin oil
Download the tech guide from eaton I mentioned. It is written in simple terms for the average tech to use and will make it all clear as mud.
Think of a driveshaft as a balanced tire on a rim. If you take the tire off the rim and rotate it 180* what happened to the added wieghts? They all got moved around even though nothing has physically changed other than orientation. This is the reason that a good tire tech will break down a tire and rim and reasseble it if it takes to much wieght. Then again I had a guy balance a tire for my truck with over 14 ounces of wieght.
Old 01-01-2014, 08:39 PM   #22
slomotion
Old Duffer
slomotion's Avatar
Thank you Burnin, I understand the tire and wheel analogy, but theoretically, it seems if the wheel, and the tire were balanced separately then assembled without disturbing the balances, it shouldn't matter what the orientation of the assembly is. (Of course that whole theory thing gets blown away when it comes to driveshafts )
and WC T5 trans.
'81 G10 Shorty Van
Old 01-01-2014, 11:34 PM   #23
Keith Seymore
You guys are mixing metaphors.
Balance is a "first order of rotation" issue; meaning - you get one disturbance per rev of the drive shaft.
U joint issues (like phasing) are a "second order of rotation" issue; meaning you get an acceleration and a corresponding deceleration for each rotation of the shaft, or two "bumps" per rev. Phasing addresses the accel/decel pairing and causes them to cancel each other out rather than adding together and transmitting the disturbance into the shaft.
They are two separate failure opportunities that are resolved in two entirely different fashions, even though they reside on the same part.
The tire/wheel analogy is actually a pretty good one, in that the wheel and the tire are "balanced" seperately but then again as an assembly. We adopted that idea for vehicles that are especially sensitive to imbalance (vehicles with large interior volumes, like an SUV or an M/L van) and "system balance" the driveline. We assemble all the components, including the shafts to the rear axle and balance that as a unit. They are marked, dissassembled for shipment and then reassembled in the same orientation at the vehicle assembly plant in an attempt to control driveline related "boom" and/or drumming (low freqency noise). For vehicles that are not that sensitive, like pickup trucks, we do not go through all the additional effort, expense and complexity.
K
1979-1986
1986 - 2019
Old 01-02-2014, 04:18 PM   #24
brad_man_72
the boat guy
Unhappy Re: two piece or one piece drive shaft
Multiple piece drivelines must be ballanced as an assembly!
Yokes, ujoints, tubing and welds aren't centered, straight, or ballanced. The multiple piece driveline is very ballance sensitive beause the stub that goes through the carrier bearing locates the front of the rear shaft and must be straighter that say a weld yoke on the end of the shaft. If you start moving stuff around the ballance will change. Even if you mark everything just removal and reinstalition will upset the ballance.
How do you ballance a driveshaft attached to the axle? Seems like a lot of mass attached to the driveshaft.
We always just use a pinion yoke and make sure the ujoint is within a couple thousanths of being centered, ballance the yoke then the shaft. Which isn't perfect because the pinion being used in the vehicle isn't going to hold the joint that close to center or be ballanced. We also make sure the trans yoke is centered which is much easier.
Old 01-02-2014, 06:50 PM   #25
Keith Seymore
Shafts were manufactured by GM Parma and axle assemblies by Detroit Gear and Axle. The two components were shipped to Dynotech (Balance Engineering) in Troy, Michigan, where the axle was constrained in a fixture (like it would be in a vehicle), a shaft selected, mated to the axle and the whole assembly balanced. This would take into account any imbalance or dimensional variation in either the tube or the longitudinal portion of the axle assembly (like a slightly squashed tube, imperfectly welded tube end or rear axle pinion flange runout).
They were then marked, dissassembled and placed together in the dunnage, and shipped to GM Baltimore (or the respective assembly plant) for installation in a vehicle.
K
1979-1986
1986 - 2019
