Old 07-17-2003, 03:48 PM   #1
Alexis
Member since 2000
Alexis's Avatar
wierd thought- rear suspension coil setup
I was thinkin. would our truck not handle better if the coils sat outside the trailing arms, closer to the axles with a inward tilts kinds like "/" <--saying this would be the left coil?
Alexis is offline   Reply With Quote
Old 07-17-2003, 04:46 PM   #2
cdowns
cdowns's Avatar
no because the way the bushings are in the trailing arms they go up and down
Old 07-18-2003, 03:46 PM   #3
raggedjim
raggedjim's Avatar
Alexis, I've got a magazine at home where they removed the coils and shocks and put coil overs behind the axle. If you want I'll mail the book to you. It's a cool setup.
Roger
raggedjim is offline   Reply With Quote
Old 07-18-2003, 06:43 PM   #4
TIMSPEED
TIMSPEED's Avatar
aka: They back-halfed it.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-19-2003, 09:58 AM   #5
raggedjim
raggedjim's Avatar
Nope, it ain't back-halfed..
Rg
Old 07-19-2003, 07:03 PM   #6
Alexis
Member since 2000
Alexis's Avatar
i put more thought into put did not type it out. iw ill tonight though so you guys can see what I'm talking about.
Old 07-29-2003, 10:47 AM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
The farther the shock (coilover) is tilted away from being perpendicular to the ground, the less effective it is at damping.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-29-2003, 10:35 PM   #8
crazy longhorn
Fabricate till you "puke"
Coil overs on trailing arms..... http://www.classicperform.com/tech_a...coil-overs.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-30-2003, 02:58 PM   #9
raggedjim
raggedjim's Avatar
That's the article!!!
Rg
