12-30-2013, 01:43 PM | #1 |
Front Drum Wheel Cylinder
Trying to overhaul my front drum brakes and got everything apart, only to find that the cylinder that I removed doesn't jive with the replacement. The one removed was attached with 2 bolts, the new one has a hanger/loop that appears to just slide over the post/spring retainer on the backing plate. Just basic 11" drum brakes with the 2" shoes. Seems like everything I read says I have the right part, but is it just a press fit that is held on my the rest of the hardware, nothing is threaded or bolted on? Thanks!
12-30-2013, 06:53 PM | #2 |
Re: Front Drum Wheel Cylinder
Let me look it up in the service manual...what year?
12-30-2013, 07:02 PM | #3 |
1970 Jimmy - 4x4
12-30-2013, 07:24 PM | #4 |
I had the same exact same problem take the old ones to Auto Zone or O'reillys and compare to 1969 Chevy Blazer NOT 1970 GMC Jimmy
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
12-30-2013, 07:17 PM | #5 |
cant even find a part number that gives me confidence...I have seen 3/8 opening is required with locking front hubs, but the ones for trucks seem to have 7/16, I wish one time something would be easier than I thought it would be...If I didnt already dump a bunch of money into new ball joints, etc I would just go get a new disc axle and be done with it!
12-30-2013, 08:17 PM | #6 |
yep orangeK5 - that was it, should have just done that in the first place, thanks for the help!
