Old 12-31-2013, 07:50 PM   #1
Drewkimble48
Unhappy 86 c10 with djm suspension. Help me get rid of most of my shims on my upper arms!
Alright so I'm new here jus to let you guys know, I have a 86 Chevy short wide with the upper lower sand drop coil springs from djm. Well my problem is that I have a ridiculous amount of shims on the upper control arms that I want gone. I have measured from frame rail to frame rail on the truck to see if I had any issues with the frame in which I compared to another frame and both measured out the same. The truck has had he alignment issue ever since we installed the control arms on it and it bugs the hell out of me. I am hoping someone has had this same issue as me and that we can finally resolve it. I really don't want to get a different set for the truck as i am in the process of becoming an aircraft dispatcher somewhere thank you for your time guys and have a good new year!
Drewkimble48 is offline   Reply With Quote
Old 12-31-2013, 11:59 PM   #2
875.3CHEVY
Re: 86 c10 with djm suspension. Help me get rid of most of my shims on my upper arms!
they make offset control arm shaft kits.i think there a .5 inch offset.
875.3CHEVY is offline   Reply With Quote
Old 01-01-2014, 12:03 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board.
Put stock a-arms back on it with drop spindles and drop springs.
DJM "drop pocket" style a-arms are old technology.
They are the only manufacturer that makes this style.
Keith
Convert to disc brakes.
Old 01-01-2014, 01:15 AM   #4
Drewkimble48
Wouldn't I have to replace the lowers as well if I went with stock upper arms? I really like the height it sits at now. If I could get the 5 inch drop up front again that would be awesome
Old 01-01-2014, 01:25 AM   #5
lolife99
lolife99's Avatar
Yes.
Stock uppers and lowers,... or just stock lowers.
3" Belltech drop spindles.
2" drop spring
Keith
Old 01-01-2014, 06:50 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Measure and make a spacer. then use 1or 2 shims to adjust. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-01-2014, 07:33 PM   #7
Drewkimble48
With the 3 inch drop spindles, I take it that the 15 inch rallies I have now, the tie rod ends would probably hit the rim. Also I did get a shim machined for at least 1/2 inch thick. When I can I'll get a picture of it. I'm actually no where near it
Old 01-01-2014, 07:39 PM   #8
lolife99
lolife99's Avatar
That would depend on the wheel backspacing.
Belltech and others moved the tie rod arm "in" when they cast the spindle.
You can't compare them to the design of the stock spindle.
This is why the wheels are "toed-out" after installation,... and why you need a new front end alignment.
All of this has been discussed many times in many threads on here.
People have been running drop spindles and rally wheels since the 80's.
Keith
Old 01-05-2014, 07:35 PM   #9
Drewkimble48
Here's a picture of the alignment shims. I thought there was more shims but you can see the spacer that I put in there as well
Old 01-05-2014, 07:42 PM   #10
Drewkimble48
Here's a picture of my orange truck that I thought I throw in did all the body work and had a friend paint it. Also rebuilt the motor not to long ago. 406 SBC
Old 05-24-2017, 11:09 AM   #11
eddiedeville
Having the exact same problem with my 86 with DJM drop arms in front, 3 alignment places have told me the same thing "no room for anymore shims" one even charged me for basically doing nothing. im seeing from this thread im most likely going to have to invest in doing the spindle and strut setup up front if i ever want to have a nice aligned lowered truck.
eddiedeville is offline   Reply With Quote
