Old 01-03-2014, 11:01 AM   #1
novafrog
novafrog's Avatar
temp.gauge trouble
the temp.gauge worked,till the green wire grounded out,after I fixed the bad place in the wire it never worked again,what can I do,thanks in advance
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears
70 nova 5.3,350 trans
80 z28 350,350,trans,bought new
03 cat.
06 gmc swb ext cab
novafrog is offline   Reply With Quote
Old 01-03-2014, 01:45 PM   #2
Molberg
Molberg's Avatar
Re: temp.gauge trouble
Is it pinned out of range and stuck? Or within operating range and just dead?
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 01-03-2014, 07:49 PM   #3
novafrog
novafrog's Avatar
setting on c(cold) a the time,thanks
03 cat.
06 gmc swb ext cab
Old 01-04-2014, 12:28 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Having the green wire grounded would give a reading of full hot. If you have an open in the wire or your fix is no good the gauge would read hot all the time. Providing you have power on the hot side with the key on.
If you have an open circuit on the hot side of the gauge it would freeze at the last reading before the open. You need to check for power on the gauge with the key on, on the hot terminal.
See the diagrams.
Name:  Dash  Layout Final.jpg
Here's how the gauge is wired.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-03-2014, 02:17 PM   #5
Longhorn 70
Longhorn 70's Avatar
also look at the runs on the back of the flex-circuit. One may have opened up.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-03-2014, 07:48 PM   #6
novafrog
novafrog's Avatar
what do you mean,one of the copper runs on the circuit board came apart,if so does that mean circuit board is no good,thanks
03 cat.
06 gmc swb ext cab
Old 01-03-2014, 11:48 PM   #7
Longhorn 70
measure them with an ohm meter. If they show open, they can be jumped with a small wire.
Old 01-04-2014, 10:07 AM   #8
novafrog
novafrog's Avatar
when it warms up a little,5 above right now,will let you no what happens,thanks to all for imfo.
03 cat.
06 gmc swb ext cab
