![]() Join Date: Jan 2003
98 GMC door hinges
I replaced the pin/bushings in the driver's door this evening. There is still some slop and I found that it is in the bottom hinge where the pin goes through the bottom of the
cab side hinge. The hole is a little oblong towards the cab. Does anyone know of a kit that would allow the hole to be drilled and a bushing installed (or something similar)? I'm considering building the back of the hole up and cleaning it up with a burr, but I was curious if there was a aftermarket solution. This is for my 98 in my signature, thanks.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
Re: 98 GMC door hinges
If you have a way to weld it another option is to weld a heavy washer in the correct position to hold the bushing.
Tags |
bushing, hinge, pin |
