Old 01-05-2014, 09:33 PM   #1
Cam1968rsss
Smile Front Sway Bar?
Hi all, happy new year. Have a question for you guys. Have a 1972 Cheyenne Super SWB. Did this truck ever come with a front sway bar? If not could I put one on it from a another 67-72 C10?
Eddie
Cam1968rsss is offline   Reply With Quote
Old 01-05-2014, 09:35 PM   #2
heathbirkendahl
Re: Front Sway Bar?
Eddie
Yes, you can. It will bolt right up. All the holes are there.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 01-05-2014, 10:32 PM   #3
hfd410
hfd410's Avatar
Re: Front Sway Bar?
you can pull one off of any square body Chevy truck too. Mine on my 71swb came off of an 81 3/4 ton
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 01-05-2014, 10:50 PM   #4
davischevy
davischevy's Avatar
Re: Front Sway Bar?
All the holes are there, but you will have to cut one rivet on each side at the cross member and frame connection. Not a big deal. An air chisel will take the head right off the rivet, and you can punch it out.
davischevy is offline   Reply With Quote
Old 01-05-2014, 10:53 PM   #5
71swb4x4
71swb4x4's Avatar
Re: Front Sway Bar?
Find a BIG one off a square body one ton. The last one I put on I bought the brackets at the Chevy dealership, that was only a couple years ago so they may still stock the brackets .
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-06-2014, 10:06 AM   #6
Molberg
Molberg's Avatar
Re: Front Sway Bar?
X2... mine was an 1 1/8" off an early 80's 2wd 1 ton. I had to fab the frame brackets..
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 01-05-2014, 11:10 PM   #7
LEEVON
Moderator
LEEVON's Avatar
Re: Front Sway Bar?
Yes they did and they are a MUST, your ride will improve drastically. As mentioned, they were common in later trucks. I saw 3 in the junkyard last week.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-06-2014, 12:54 AM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Front Sway Bar?
Check the FAQ section on the site. Member Texas Firefighter has an in depth-faq that I used when I installed my front sway bar. This is one of the best inexpensive upgrades you can do to your truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-06-2014, 10:04 AM   #9
KMC3420
KMC3420's Avatar
Re: Front Sway Bar?
Here are a few.
http://67-72chevytrucks.com/vboard/s...d.php?t=606842
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 01-06-2014, 10:26 AM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Front Sway Bar?
You can also buy a swaybar kit from ECE or Hotchkis or Porterbuilt etc.
Tom Vogel is offline   Reply With Quote
Old 01-06-2014, 03:20 PM   #11
Redline novdog
Redline novdog's Avatar
Re: Front Sway Bar?
My $.02. bought a used bar 1 1/8. I bought the rest from local Chevy dealership. The rubber grommets # 3927019,the brackets for the grommets #334671,and the frame brackets #6271375,You need two frame brackets. This worked great on my 67 lwb.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-06-2014, 06:56 PM   #12
NobleSix
Re: Front Sway Bar?
very nice! just found something to keep me busy the next coupla days
'69 c10 longbed granny 4spd 292 "Behemoth"
'67 c10 longbed granny 4spd 292 "Burzum"
some pictures of my work in progresshttp://photobucket.com/zaeea
R.I.P. Corey "Flattus Maximus" Smoot 11/3/11
You will be missed. Your sound lives on.
NobleSix is offline   Reply With Quote
Old 01-06-2014, 08:45 PM   #13
Mr Handy
Mr Handy's Avatar
Re: Front Sway Bar?
Use grade 8 hardware to bolt everything up. it is easy and makes a big difference in handling... I am now planning to do a rear bar as well.
Mr Handy is offline   Reply With Quote
Old 01-06-2014, 09:00 PM   #14
NobleSix
Re: Front Sway Bar?
not trying to hijack this thread, but are you gonna use that blade style or regular type rear sway?
Old 01-06-2014, 09:06 PM   #15
Mr Handy
Mr Handy's Avatar
Re: Front Sway Bar?
I have not decided yet, have to much body work to do, then paint and engine refresh, then it will be time to revisit the suspension...
