Old 01-08-2014, 12:55 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
6.0/trans/case purchase ???
I have been wanting to do an LS swap or an entirely new build for a while now and have come across a 2002 6.0 with a 4l80e and transfercase with 120,000 miles on it. The guys says he has everything from the radiator to the fuel tank and lines. He is asking $2200 for it. Does that sound resonable?
What questions should I ask?
What should I look at if I go and look at the motor/trans and case? Anything specific to look out for.
Probably want to make sure it will turnover by hand?
I have a bunch more questions if I would purchase this combo but lets start here first
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 01-08-2014, 01:58 PM   #2
truckdude239
truckdude239's Avatar
Re: 6.0/trans/case purchase ???
Not bad if u get all that i got my 4.8 460le harness computer and accessories for 1100
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-08-2014, 04:28 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: 6.0/trans/case purchase ???
I got my 6.0 trans combo with 4l80e trans, computer had been reflashed for the stand alone harness. I got the fuel pump, motor mounts, down pipes with O2 senors and only paid $2200.00.
Check and make sure it turns freely and make sure all the senors and connections are with it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-08-2014, 06:47 PM   #4
6600DURAMAX
will do, might run by and take a look tomorrow since I am swamped today
Old 01-09-2014, 09:18 AM   #5
Clyde65
Clyde65's Avatar
I would hit him around 1800, 120k miles is a bit ( Not too much for an LS though) but that is where I would start.
The most expensive thing on this swap is the small stuff, so if he does have all that you said...it is much better for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-09-2014, 11:14 AM   #6
littlevictories
fwiw, I'd have gladly paid that amount if I could verify compression and pull apart the filter.
littlevictories is offline   Reply With Quote
Old 01-09-2014, 03:44 PM   #7
6600DURAMAX
What should the compression numbers be??
Old 01-09-2014, 05:30 PM   #8
littlevictories
I don't know any exact numbers, but if they are within 10% of each other I call it a good motor.
For instance, the 5.3 I picked up puffed between 185 and 190, without letting the needle build.
I'm sure these other fellas could tell you more about what a stock 6.0 oughta have. I am new to these LSx motors.
