Old 01-10-2014, 02:26 AM   #1
brokestudent
Window seals question
I have pulled apart my drivers side window, and of course every rubber seal is trash. I have cleaned the windows buffed them out etc etc and they are looking great, but now I want to paint and put back together. I want to obviously replace the seals, and I can find most of them. I cannot seem to find the seal the touches the glass and the frame of the vent window. Not the seal that goes around the frame of the vent window, but rather the one that goes in it and holds the glass in place. It rides around the curved edge of the glass as seen in the picture and sits in the channel of the went window frame piece. I would certainly entertain any vendors that make the whole kit or if anyone knows of a place that has the hole kit, particularly the part I am needing for a 1963 pickup please let me know.
brokestudent is offline   Reply With Quote
Old 01-10-2014, 07:01 AM   #2
tincan1966
tincan1966's Avatar
Re: Window seals question
Try Steele Rubber Products
tincan1966 is offline   Reply With Quote
Old 01-10-2014, 09:11 AM   #3
K98AL
K98AL's Avatar
^^100%^^
I haven't purchased that particular part, but after buying many other rubber products from various sources, Steele is the only way to go.
K98AL is offline   Reply With Quote
Old 01-10-2014, 09:48 AM   #4
brokestudent
I looked there but I can't seem to find that particular rubber piece. Does it have some specialty name?
Old 01-10-2014, 10:09 AM   #5
Jolby
Jolby's Avatar
I just got mine in yesterday from Classic Parts of America. It's called glass setting tape, for the vent window it is part # 70-751. They also have the one for the door glass, they are different thicknesses. Hope this helps.
Jolby is offline   Reply With Quote
Old 01-10-2014, 10:47 AM   #6
brokestudent
I haven't checked that particular part out but that sounds to be closer to the verbiage I was looking for thanks.
Old 01-10-2014, 01:27 PM   #7
jtrichard
you can also check with and glass shop that does automotive and ask them they should have some if they do they might just give it to you and yes it is called glass tape ....use dish soap to install it then trim off the excess
jtrichard is offline   Reply With Quote
Old 01-10-2014, 01:33 PM   #8
cg285
i had a friend over to the house, on a weekend, whose door glass frame broke from the roller channel. had to weld it so glass had to come out and getting glass tape on sunday was impossible.
so i sent him to one of the discount auto parts places and he found cork gasket material the right size. worked just fine
cg285 is offline   Reply With Quote
Old 01-10-2014, 03:15 PM   #9
doobiebro
doobiebro's Avatar
Any glass or windshield shop will carry the glass tape. I took mine to my buddies shop and he redid both vent glass and replaced one glass with out me knowing because of the bubbles in the glass as I waited for free..
They sell it in diff sizes so you might have to trim the excessive pieces if they overlap with a razor blade..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
