01-10-2014, 03:31 AM | #1 |
79 GMC 4.1L 250 Cylinder Head Advise
Hi All,
After doing a through inspection of my new purchase I discovered the the cylinder head is cracked on the exhaust manifold that is part of the cylinder head. I believe this head is known as an Integrated Head. Please correct me if I'm wrong. Anyway I'd like to replace it with a Normal I6 head that has a separate Intake Manifold and Exhaust Header. My little bit of research tells me that a 78 head might be what I'm looking for. Or as mentioned on another thread a 194 Head. More info on the 194 head would be greatly appreciated. So what might be your recommendations, keeping in mind this is a California truck. Funny thing is... I just had it smog'd and it pasted with the cracked exhaust manifold. |
01-10-2014, 07:25 AM | #2 |
Re: 79 GMC 4.1L 250 Cylinder Head Advise
If it passed smog i would just weld the crack up. Can't do much with a vehicle after 1974? In cali.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
01-10-2014, 11:31 AM | #3 |
You can swap to a non-integrated, you will need intake/exhaust/carb and the carb linkage may not work. Is yours a 1 barrel or 2 bbl carb (take off air cleaner lid, if carb top is round, 1bbl, rectangular, 2bb)? There are no factory 2 bbl non-integrated mainfolds, so you would need aftermarket intake and carb or go to factory 1bbl.
194 head has smaller combustion chambers for a little more compression, but has siamesed exhaust ports so headers don't work as well. All the other non-integral heads are about the same. late 292 have AIR plugs in them so if you have AIR you would need those. Rebuilt (or at lest cleaned and checked) integral heads show up on ebay time to time for $250-300. That's about what it costs to have a normal head reqworked, before you get the carb, intake, and exhaust. Just make sure you get the right one, and expect to add new rockers / gaskets, etc. Oh, and buy Leo Santucci's book, version 2. Lots of good info on L6 even though it's heavy on race prep.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
01-10-2014, 12:28 PM | #4 | ||
01-10-2014, 07:26 PM | #5 |
My '78 California Truck has the crappy integrated head.
01-12-2014, 02:51 AM | #6 |
01-12-2014, 02:26 AM | #7 |
Talked with John from Autowerks today from Iowa and he said any I6 head can work from the 230 to the 292, but may need combustion chamber work. His machined & ported heads go for about $1,100... that's what I paid for the whole truck! Not sure if I'm ready for that. I'm going to keep a lookout for a non-inter-grated head. I'm thinking checking cylinder head gaskets to see what models they fit. Which may be a good clue where to look.
01-12-2014, 09:54 PM | #8 |
My 78 federal emissions C10 has the non-integrated head / 1bbl carb. Truck has been in the family since factory order and has 250K miles on her. Never been apart. Great engines! I would imagine you could swap it to a non-integrated and hope the smog guy is too young to even know what a L6 is but...........that's pushin your luck. I would try and find another integrated head even though they are problematic...
01-13-2014, 03:39 PM | #9 | |||
I see you live in California, and your 79 Chevy C10 non-intergated head passed smog I take it. Does your engine have these items pictured below. The vacuum valve is attached to the detachable header, so I may be able to find a non-intergrated header with that smog valve. For some reason it rotated the pics when I uploaded them. Quote:
Thanks all! Jim Last edited by 79GMCSierra; 01-13-2014 at 03:40 PM. Reason: Spelling |
01-16-2014, 12:43 PM | #10 | |
Mines a 3 spd also (back on the column again) and sometimes I think that's the best theft deterrent around. Nobody knows how to drive them anymore! |
01-16-2014, 02:59 PM | #11 | |
01-13-2014, 10:31 AM | #12 |
I'm sort of hodgepodging a few trucks together to make one....long story short.....I started with an integrated head 250L6 motor and am now switching to a non integrated 194 head as a result of speaking with Tom Langdon........in a nut shell, he believed if the integrated head didn't already have a crack, it would soon would.
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
01-13-2014, 11:17 AM | #13 |
I have a 331184 on a 250ci that I bought in a 1979 nova. You might want to look for that part # .
01-13-2014, 04:52 PM | #14 |
Kid's Mechanic
When you get ready to remove the integrated head , Have an extra set of hands close . I weighed mine and it was 142 lbs .
01-13-2014, 05:41 PM | #15 |
