Old 01-10-2014, 10:43 PM   #1
mobileortho
mobileortho's Avatar
Alternator question
My alternator stays on when the engine's off, it won't even turn off when you disconnect the pigtail. It seems to be charging fine, not sure if it needs to be replaced. Any ideas?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 01-10-2014, 11:07 PM   #2
wildfifty2
Re: Alternator question
Your alternator should only turn when the engine is running as it is driven by the belt. Am I missing something?
wildfifty2 is offline   Reply With Quote
Old 01-11-2014, 12:00 AM   #3
mr48chev
mr48chev's Avatar
Stays on How? In other words what indication causes you to believe that it "stays on"?
My ongoing truck projects:
Old 01-11-2014, 12:54 AM   #4
mobileortho
You can hear it humming.
Robert C.
1950 3600
Old 01-11-2014, 02:20 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
pull your belt off and if the pulley spins the Alt needs to be replaced
Old 01-11-2014, 05:08 PM   #6
mr48chev
mr48chev's Avatar
I've read some strange suggestions on the net but that one tops the list. You can motor a generator but I have never heard of it with an alternator.
From what I can find out by a search the alternator is getting feedback that is telling it to charge when it sitting static.
Old 01-11-2014, 05:50 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
A car/truck 12 v alternator is a 3 phase synchronous motor why would it not be able to run under power? I'm surprised you have never seen and alternator turn by itself. It does need to have a diode problem to do this. I'm always glad to be on the top of the list.
Google "alternator as a motor" you will find all kinds of crazy stuff they do with alternators as motors. search youtube, you'll see real crazy stuff there
Old 01-11-2014, 08:44 PM   #8
Nordic
Nordic's Avatar
Do you have a diode in the harness.... possible backfeed to the alt.
Nordic is offline   Reply With Quote
Old 01-11-2014, 10:09 PM   #9
59stepside
59stepside's Avatar
I'm just thinking off the top of my head....alt gets power from ignition switch on power for the exciter I believe. So I would just check with a voltmeter your connections. Depending on the style, you should have the main wire that runs directly to the battery and a smaller wire with it that should be terminated near the battery or junction block near battery which senses the voltage. This wire is usually just jumper back to the main wire at the alternator. (Which is not very effective btw). And thirdly there should be power from ignition switch keyed on. If this is getting power with ignition off that could cause your problem. With truck turned off and power applied to that wire, it will sense below its set voltage and constantly try to charge/run.
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 01-11-2014, 10:12 PM   #10
59stepside
59stepside's Avatar
So you can see the two red wires, they will have 12-14v. The third wire labeled brown but could be any color, usually white should only have voltage with key on. If I remember correctly. If I am wrong please correct me.
USCG Aviator
C-130
Old 01-11-2014, 11:51 PM   #11
mobileortho
Got an online coupon for $50 off @ Advance Auto so I just bought a new one, problem solved.
Robert C.
1950 3600
Old 01-12-2014, 12:55 PM   #12
wildfifty2
$50 coupon... where do I sign up??
Old 01-12-2014, 11:50 PM   #13
mobileortho
It was part of a Dec. promotion. I made an online purchase and they sent me.
Robert C.
1950 3600
Old 01-13-2014, 09:23 AM   #14
Highsider
Highsider's Avatar
Cool to get a credit that large.
Last fall an Advance Auto lifetime guaranteed heater motor failed on my rv.
When I exchanged it, the new one was cheaper and they handed me a $1 cash refund.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 01-12-2014, 10:01 AM   #15
59stepside
59stepside's Avatar
Hopefully. :-)
USCG Aviator
C-130
