01-11-2014, 12:17 AM | #1 |
WTB- Passenger vent door handle and mount
Looking for the passenger vent door handle the one that mounts to the kick panel. I need the rod that attaches to the vent door, the clip that holds the rod on the vent door, the bracket that screws to kick panel and the handle. This is for a AC truck if that matters. Not sure if the handles are different from the driver and passenger. Thanks
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
01-11-2014, 01:44 PM | #2 |
Re: WTB- Passenger vent door handle and mount
I may have what your looking for. I will check on Sunday. If I do, I can drop it off to you around the 26th as I have meetings in SA that week. I will let you know what I have on Sunday
01-11-2014, 01:52 PM | #3 |
Ok sounds good
01-12-2014, 12:38 AM | #4 |
if that does not work out let me know I think I have one as well.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
01-14-2014, 12:51 AM | #5 |
Ttt
01-14-2014, 07:51 AM | #6 |
If the other 2 guys can not get you fixed up then I do have what you are asking about but all the A/C cabs that I have seen use a vacuum pod on the right vent instead of a manual handle. I might be wrong and you probably can use the manual on anyway but I really think that is how they are stock. $11.00 shipped
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
01-15-2014, 07:02 PM | #7 |
I found the parts you are needing, that yours for free if you want them. I will be in SA on the 26th if you want I can bring them to you then. If you need them earlier, we can meet somewhere between the two of us. I Sent you a pm with my contact info.
01-15-2014, 07:39 PM | #8 | |
Jeff,
A/C trucks do not have a manual cowl vent on the passenger side. Those vents are vacume operated by the A/C control. Quote:
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
01-15-2014, 07:40 PM | #9 |
Ok thanks that's what I was thinking. Ooops. Should of done my homework. Thanks
01-15-2014, 08:39 PM | #10 |
Have that one also if you need it it's yours.
