Old 01-11-2014, 01:59 AM   #1
cigar-
cigar-'s Avatar
Bell crank question
I am doing a motor replacement in my 71 half ton. Originally the motor was a 250 inline six. A previous owner put a 350 V-8 in the truck. The motor was bad, I bought a new one and the install will hopefully be this weekend.
The bell crank that came out of the truck shows the arms having been cut and re-welded. The bell crank I have has a slight bend in it. I bought another crank from a guy that dismantles these trucks and it came from a V-8 truck. The one I got is straight. The new one is about one half to five eighths of an inch longer.
Has anyone done this change out and encountered the same issue? I can only assume the old one got modified for some reason (to possibly clear the exhaust manifolds which have been changed from original). The original drivers side exhaust originally swept in and back. The one that came on the truck drops straight down. I plan on going back to the original configuration.
Any and all help is much appreciated. Thank you. I can and will post photos of the two bell cranks if that helps.
Michael
cigar- is offline   Reply With Quote
Old 01-11-2014, 09:40 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Bell crank question
[QUOTE=
Michael[/QUOTE]
Please do that.
Tom Vogel is offline   Reply With Quote
Old 01-11-2014, 12:22 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
The only issue I have is that the mount is different on the frame between the 6 and 8's. That has made me have to mod the Z bar.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-11-2014, 04:04 PM   #4
cigar-
cigar-'s Avatar
Smitty,
I had a funny feeling there was a difference. Can you tell me what mods you had to do?
Michael
Old 01-11-2014, 04:05 PM   #5
cigar-
cigar-'s Avatar
I will have photos up within an hour!!!!
Old 01-11-2014, 05:24 PM   #6
cigar-
cigar-'s Avatar
Here are the two bell cranks.
Old 01-11-2014, 10:31 PM   #7
71meangreenc10
Originally Posted by cigar- View Post
Smitty,
Michael
I put a welded up one in mine, but I heard you can take a V8 one and cut it down and it will work.
Smitty
71 C30 Wrecker
Old 01-12-2014, 09:41 PM   #8
cigar-
cigar-'s Avatar
Hopefully someone will read this two day old thread......
So that I get things right, is there anyone out there in Southern California with a C10 truck, V-8 motor and a stick shift?
I would like to have a look at the position of the bell crank bracket and the bell crank itself. Maybe I'm the dumbest guy on here but fitting the pivot ball and crank are giving me fits. I have three bell cranks....one that us bent (came off the truck), one from a V-8 C10 and one from what I don't know.
I need to see which one works best or correctly. Based on a previous reply above I don't know why Chevrolet would mount the bracket on the frame in different locations on V-8 versus an inline 6. Yes, I know the motors are different size and design but it still perplexes me!
I appreciate any and all help.......
Michael
Old 01-12-2014, 09:57 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Michael
There is also two positions that the engine sits in depending on which engine, and whether two or 4 wheel drive. If you look at the frame where the engine mount stands bolt on you will see an extra hole either in front of the stand or behind it. The engine can be moved that far back "or" forward. I will see if I can find a picture. I know there have been some posted on here.
LockDoc
Leon
Old 01-11-2014, 06:52 PM   #10
truckdude239
truckdude239's Avatar
The bottom one is right the other has bent bent to fit more then likey they did not move the motor to th v8 spot or if the did to move the brakets to line up
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-11-2014, 10:09 PM   #11
burnin oil
or someone tried to pull the motor without unhooking it.
burnin oil is offline   Reply With Quote
