Old 01-11-2014, 01:40 PM   #1
kaycee
kaycee's Avatar
Bushing Grease
I put all new poly bushings in the ride and have read where you get an annoying squeek over time.Is it as easy as I think to just add a grease zerk to remedy the future problem.As tight as they pressed in it is hard for me to belive the grease will spread around the bushing.Allso what other available grease do you all use the tiny little tubes they send are a freaking joke.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 01-11-2014, 05:53 PM   #2
bdiamond
Re: Bushing Grease
Waterproof bearing grease. I think its marketed as boat trailer bearing grease. Oreilleys or Autobone should have it
bdiamond is offline   Reply With Quote
Old 01-11-2014, 06:11 PM   #3
cdowns
cdowns's Avatar
Re: Bushing Grease
for poly bushings i've always used the special poly use silicone bushing grease
Old 01-11-2014, 11:24 PM   #4
66 C10 383
Re: Bushing Grease
I've been researching this myself. I've used poly before and had squeaks and don't want a repeat performance this time around.
Concerning the tight fit of the inner sleeve into the bushing itself, you do have to mill or file grooves into the poly bushing to allow the grease to flow between the sleeve and bushing. Do a search on "grease fittings on poly bushings" and you'll get a bunch of sites showing how to do this. It may be on a Mustang site or Miata site but a poly bushing is a poly bushing ... the idea is still the same.
Last time I replaced my poly bushings with a greaseable solid bushing (alum, delrin, steel inner sleeve) and it was MUCH better but that option doesn't exist as far as a bushing for stock truck arms goes ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 01-12-2014, 12:16 AM   #5
66 C10 383
Re: Bushing Grease
Here's the site I got my general idea from ...
http://www.924board.org/viewtopic.ph...asc&highlight=
Doug
