01-13-2014, 11:32 AM | #1 |
Hydroboost: what size aftermarket master cylinder?
I didn't want to step on Mooseknuckles thread since mine is a bit different.
What bore master cylinder would you suggest if swapping to hydroboost? I have the "boost" setup and am tired of my current master cylinders leaking so I was going to step up.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-13-2014, 04:14 PM | #2 |
Re: Hydroboost: what size aftermarket master cylinder?
Assuming its 4 wheel disc 1 inch Wilwood is what we use.
01-14-2014, 07:19 AM | #3 |
Does this bolt on directly? In other words, if I have hydroboost, all I would have to do is just swap out the master?
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
01-14-2014, 09:18 AM | #4 |
Yes it will bolt right on. They come in 3 finish options natural,Media Burnished (light polished) and black. You can also get it with prop valve installed.
Pm me on pricing. |
01-14-2014, 01:29 PM | #5 |
I will drop you a PM for some pricing but mine is front disk and rear drum, nothing fancy. I do have the wilwood D52 replacement up front.
I had collected the makings for a swap but didn't have the master cylinder plus my "factory" one looks like crap and I seem to have a bit of seepage I can't fix.
01-14-2014, 06:07 PM | #6 |
The master will be fine on disc drum as long as it has a prop valve 10lb residual vavlve.
01-30-2014, 05:29 PM | #7 |
I got this on mine for cheap. 40$ i think. Mine came with a nice looking reservoir ,
http://www.autozone.com/autozone/par...dentifier=2097 I had to elongate the holes for it to bolt up. Uses standard 3/16 line inverted flare fittings |
