Old 01-14-2014, 12:45 PM   #1
bodydrop72
building control arms need some info.
Hey all brought my truck in and tore it apart for a rebuild. I wanna build new control arms as mine have been modified and don't look to good anymore. I've been trying to locate the billet cross shafts like the ones CPP uses so I can run poly style bushings. I'd much rather build my own than buy bolt ons
bodydrop72 is offline   Reply With Quote
Old 01-18-2014, 07:51 PM   #2
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: building control arms need some info.
Hi bodydrop72. Welcome to the forum! I'm moving this to the Suspension area for you so you can get some help with this.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-18-2014, 07:55 PM   #3
Bhelton
Bhelton's Avatar
Maybe porter built will sell them to you, if not you may want to start at a local race shop
Bhelton is offline   Reply With Quote
Old 01-19-2014, 10:14 AM   #4
Snailed
Snailed's Avatar
You may find Delrin or UHMW is a lot more durable, rigid and quiet than poly for your bushings. You can get billet cross shafts from all kinds of roundyround supply places.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 01-19-2014, 03:42 PM   #5
theastronaut
theastronaut's Avatar
Been looking for .5" dropped cross arms myself for the upper A-arms with no luck. Can't find them with or without the drop that fits the original mounting points. Hotchkis has them but won't sell them separately. I'm using standard 73-87 lower shafts and having a machine shop make delrin bushing. I'd definitely look into delrin or UHMW as posted above instead of urethane.
theastronaut is offline   Reply With Quote
Old 01-19-2014, 04:45 PM   #6
Snailed
Snailed's Avatar
Maybe fabricating a cross shaft out of steel would work for you? A heavy wall DOM or chromolly tube with sleeved mounting holes could be made with a minimal amount of work and the bushings could be sized to ride on it's OD. The sleeved mounts could be offset to change height and/or anti.
Seems like welding new mounts on the frame to use a ready made shaft might be easier and allow the same geometry changes.
