Old 01-15-2014, 12:03 AM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
What leaf spring hardware to use?
I'm replacing my front and rear leaf springs on my 70 K10 with a 2-1/2" Skyjacker lift and need to replace the spring bolts. I have new U-bolts with the kit, but I'll need new front and rear leaf spring bolts and shackle bolts. I'm wondering what to use for replacement hardware? Is the bolting that LMC sells anything special, or can I just buy grade-8 bolts at a hardware store? What have you guys used and what do you recommend? Thanks.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-15-2014, 01:21 PM   #2
derotoreut
derotoreut's Avatar
Re: What leaf spring hardware to use?
Come on now, I know many of you have replaced leaf springs. What hardware did you guys use and where did you buy it? Did you buy the bolting from NAPA, LMC, online somewhere, a local spring shop? Any help is appreciated.
~ Dan
Old 01-15-2014, 08:33 PM   #3
oldschool18
oldschool18's Avatar
grade 8 bolts, washers, lock washers and nuts and I used some Loctite.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-15-2014, 10:23 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Grade 8 bolt, lock washer, and jamnut from the local hardware store (they sell them by the pound). I ensure that the shoulder of the bolt is long enough to go through the entire bushing sleeve, even if I have to trim the overall length once installed.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-15-2014, 10:29 PM   #5
KY_GMC
KY_GMC's Avatar
I found hardware at RockAuto and Husky Spring.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 01-15-2014, 11:42 PM   #6
70LonghornCST
Moderator
70LonghornCST's Avatar
Hi derotoreut! I went ahead and moved this to the Suspension forum for you. Good luck on your project
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-15-2014, 11:49 PM   #7
mrolds88
Grade 8 all the way. I would use the all steel locknuts (as opposed to the nylon insert locknuts) Little bit of locktite never hurt anything either!!
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-16-2014, 07:24 PM   #8
derotoreut
derotoreut's Avatar
I had to cut everything so I don't know sizes. Any ideas?
~ Dan
Old 01-16-2014, 10:28 PM   #9
KY_GMC
KY_GMC's Avatar
Check out this website. http://www.huskyspring.com/
The listing has a couple of options.
Call them, they are easy to deal with.
Build Thread
Engine Thread
Old 01-18-2014, 05:01 PM   #10
derotoreut
derotoreut's Avatar
It looks like mine are 9/16" by about 4-1/2" long. I heard that some could be 5/8" bolts. I think I'll do like Lowrollin70GMC says and get them from a local hardware store. A lot cheaper then buying them from LMC or spring company. Grade-8 too.
~ Dan
Old 01-18-2014, 11:32 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Should be 5/16, 3/8, or 7/16 bolts.
9/16 center bolts are not used on common light vehicle springs.
The bolts you buy from a spring shop are fully threaded so they sell you the next longest bolt to what you need and you trim them shorter after installation. I just bought a pair at my local spring shop this week for 3 dollars each.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-19-2014, 12:00 PM   #12
derotoreut
derotoreut's Avatar
I am referring to the rear spring eye bolts and shackle bolts. So far this is what I've found:
http://www.sdtrucksprings.com/index....ducts_id=16134
http://www.autoandtrucksprings.com/p...-1442-211.html
I just measured my new leaf spring eye bolt holes and it looks like 9/16"
~ Dan
