Old 01-15-2014, 11:04 AM   #1
jmorri34
jmorri34's Avatar
Camaro gas tank ?
I am curious to know something. I would like to relocate the gas tank to the rear and see everyone using the tanks that go to the bed or to the tail light. I personally would like the thinner profile early model camaro tank that has the filler behind the plate in the rear. My truck is lowered and I dont see many people using them and it seems the most common theme is the other style. My question is this, will it fit within the frame rails and why dont people use the camaro tank more often. Is there some reason I dont know , see , or understand. I have received tons of help from here and love this sight and figured you guys could help me on it. Thanks a ton for all of the help and anything you can offer on this one!! Jerry
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 01-15-2014, 11:09 AM   #2
jmorri34
jmorri34's Avatar
Re: Camaro gas tank ?
ok so I see it wont fit between the rails but Id still like to know why people dont use the camaro style more!!
1969 cst prostreet
Old 01-15-2014, 11:27 AM   #3
Rod Run
Rod Run's Avatar
You pretty much answered your own question.
Why would anyone want to go through the trouble of trying to mount a tank that doesn't fit? If there were no other options, then I guess I would understand, but there are other options out there.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 01-15-2014, 02:20 PM   #4
jmorri34
jmorri34's Avatar
Yea I understand that I have just seen a few guys do it and I dont like the fat tank that goes in between where the only option I see is to cut a hole in the bed or go through the tail light. I was hoping because it was a little thinner it wouldnt be so low to the ground but guess theres not much sense in doing it. Thanks for straighteninig me out lol!!
1969 cst prostreet
Old 01-15-2014, 07:13 PM   #5
rogergodding
rogergodding's Avatar
If you have rear coil springs, you can use a chevelle tank. It will lay flat against the frame and does not hang too low....
rogergodding is offline   Reply With Quote
Old 01-15-2014, 07:16 PM   #6
rogergodding
Here's a link for you to check out:
http://67-72chevytrucks.com/vboard/s...d.php?t=564509
Old 01-15-2014, 08:51 PM   #7
54belair
54belair's Avatar
Ive installed one in my build--pics are there.
My install was a 69 camaro tank, filler behind the plate. The truck is lowered 4" in the back. The tank overhangs the frame rails by about 2" on both sides. The only issue with the overhang would be if you were going to use stock location exhaust pipes.
Even with the 2" or so drop below the frame rails--the tank still sits Above the bottom of the diff. For my use of the truck this wont cause an issue at all.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 01-16-2014, 02:37 PM   #8
jmorri34
jmorri34's Avatar
Thanks for the info yall, This will help me a ton!
1969 cst prostreet
