Old 01-16-2014, 12:52 AM   #1
rhm63
bed and fuel filler advice needed
First off I know there are lots of threads on gas tank relocation, I have a question that I have not been able to find the answer to.
I have installed an older blazer tank in the rear and I think I have a good idea for a temporary (a few years as non-daily driver use) filler neck location. I just want to get some feed back before I go all in.
I will be installing a full sheet of plywood as a cheap bed without the bed strips. I was going to build a wooden box on the side for the fuel filler. I was thinking it should be 3-4 inches off the bed floor. I was thinking of using a marine Perko vented filler.
Is there any issue with using a plastic one? Issue with using wood as the support piece? would I just put the ground to another metal part?
Also, what type of plywood would be good? (I have not really searched this).
rhm63 is offline   Reply With Quote
