Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-16-2014, 11:45 AM   #1
7dee2
7dee2's Avatar
My C30 keeps burning out the left low beam?
My 72 C30 (DD) keeps burning out the left low beam. High beams work as do all the other lights including the right low beam. The lefts seem to work fine when first replaced. I rarely drive the truck at night but have gone through 2 used good bulbs in just a few uses. What could be causing these to burn out so quickly?
Thanks,
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-16-2014, 12:08 PM   #2
7dee2
7dee2's Avatar
Re: My C30 keeps burning out the left low beam?
I guess I posted this in the wrong place to start. Appreciate the move to the Electrical section.
Thanks,
Brett
Old 01-16-2014, 01:11 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
aside from just getting bounced/banged
check the connections/ground,
are they the same brightness when on?
same flasher speed when turning?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-16-2014, 04:28 PM   #4
7dee2
7dee2's Avatar
Motornut thanks for the quick response.
Headlight is not loose, I can clean the connections (plug), they are the same brightness when on. Flasher speed, not sure how this relates but yes flasher speed is the same from left to right or 4 ways.
A little more information is the truck seems to be a 64K mile original survivor. Electrical seems to be in very good condition except for this problem.
Thanks,
Brett
Old 01-16-2014, 05:25 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
I had a broken ground in the headlight
drove me nuts.one was headlight dimmer and that turn flashed slower
PO had opened up the slide on plug, tried to attach it by rebending the plug copper over it
should be a pic in the thread below for 78 jimmy ,front grill etc was off for touch up
John
