01-17-2014, 01:55 PM | #1 |
81-87 stepside rear fender well moulding
looking for a set of rear fender well mouldings for an 87 chevy stepside. i have a set of nos fronts. tried to find answers on a couple posts here with no clear answer. i see pictures of them all the time with trim installed. yes i know they make them for the 79 and older stepside beds. anyone have a clear answer or can lead me in the right direction? i know they never came from factory this way. i want to match the front and rear and the rear looks lost without them. pictures/part numbers will help me. thank you.
01-17-2014, 02:51 PM | #2 |
Re: 81-87 stepside rear fender well moulding
They definitely came with them..Mine had them. I removed them and thru them out.
01-17-2014, 03:00 PM | #3 |
that is what i have heard from a couple other people. that is as far as i get with getting an answer. thank you. i really need to find a set.
01-17-2014, 03:48 PM | #4 |
Tried finding a set myself long before I had a stepside. Right now I've taken to modifying some rear trim to fit.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-17-2014, 04:17 PM | #5 |
I bought a set from classicparts for the rear fenders on my 86 stepside, could not find a good original set. Im quite happy with them, they are a bit thinner than the originals if I compare to the front ones. But they do the job.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
01-17-2014, 10:46 PM | #6 |
Have a part number handy?
01-17-2014, 05:05 PM | #7 |
were they for a stepside or fleetside?
01-18-2014, 12:40 AM | #8 |
I think they were for stepside, it's been a while since I put them on, so I can't remember of hand.
I Will check the parts Numbers when I get home
01-18-2014, 11:21 AM | #9 |
post a part number or pm the part number. pics on your truck?
01-18-2014, 05:09 PM | #10 |
I had a look in the garage, could not find the folder with papers from when I restored the truck. Itīs in there somwhere (still a bit messy since I moved) Im pretty sure itīs kit nr: 62-680K from Classic Parts.
I had to massage the corners a bit to get them to fit on the back fenders, but nothing complicated. Just rolled them gently on the inside curve with a piece of 3" pipe when I put them on (donīt know if you get what I mean?) The screws that came with the kit were crap, I swaped them out for selftapping ones with same flat type head (found in the local hardware store) The kit screws are so soft that if you slip once with the screwdriver the grove is gone.
01-18-2014, 05:27 PM | #11 |
thank you for the part number and pictures. beautiful truck.....
01-19-2014, 10:29 AM | #12 |
Thanks, good luck with your truck!
I just started to pull the engine out of mine, the original 305 gave in and then it sat for a year. Now I have the inspiration back to do something with it, not sure if Im going all out on an LS swap or if Im going to get a 383 for it.
