LS swap temp sending unit not working
Alright, so I recently finished my 5.3 swap in my '86. I'm using a custom temp sender adapter and the temp sender doesn't work properly. It just reads about 100* unless I put it in park and let it idle, then it rises to about 195-200. Once I start driving, it gradually goes all the way back down.
I removed the plug on the passenger side and put the adapter there. ![]() I thought maybe the coolant flow is just below the sender while driving, but it's full of coolant and others on here have used adapters in this spot just fine. Any suggestions? Last edited by EightiesOnly; 01-17-2014 at 09:15 PM. |
![]() Join Date: Sep 2005
Re: LS swap temp sending unit not working
Ive found that most coolant sesnors need the coolant flowing across the end of the sensor to work properly
#3 | |
The better thing to do would have been to drill and tap the plug whole, but it's too late for that now. |
Old member
You can get away with a shallow adapter but I think yours is to deep. Yes at idle the coolant isn't moving as fast through the system and it hits the sendor longer. But once you start driving the coolant is moving so fast and not getting to cover the whole area of the sender. My 2 cents worth anyway.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Apr 2005
Try to find an adapter that will get the temp sensor closer to the head. Dakota digital sells some I think.
http://www.dakotadigital.com/index.c...rod/prd111.htm
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#6 | |
Old member
Most gauges are matched to the sender. But you should be able to get one that works for a certain temp.
