72 Blazer Rear leaf spring bushing
I heated the spring and knocked out the bushing but It looks like a metal part of the bushing was left inside. How or does that metal part come out to install the new bushings?
Cochino_Racing_909
Re: 72 Blazer Rear leaf spring bushing
Mine also got stuck so I used a sawsalll scored the metal on both sides and then taped it out with a chisel
Ok,, Thanks for the response and help i will try that.
![]() Join Date: Apr 2012
Hi,
I need to replace the bushings on my Blazer as well. Where did you find the bushings and do you have a part number? Thanks, Paul |
I bought mine at energysuspention.com .I used a air chisel to get mine out.much quicker than manual hammer and chisel.if you got the bushing out that sleeve should have came out with it. you may still have some bushing material left in the center of the spring eye. some people burn em out with a torch.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
I got the metal rings out thanks "Angelse68cal" I used the sawsall chisel method and they came out after a few good whacks.
