01-19-2014, 01:00 AM | #1 |
Powerslave's 66 SWB LS1 laid out with PB
I finally decided to start a build thread now that I'm actually getting some progress done. I've gone 10 different directions with my truck, but it's finally all coming together. It started as a longbed but I cut the frame down and found a short box on craigslist. The truck was poorly bagged when I bought it, so I ended up re-doing most of that as well. I figured that since it was already bagged, that I'd save myself some time, but I ended up spending twice as long fixing everything. The truck had a 350/350 setup that I pulled out and replaced with an LQ4 6.0 and 4L60e. Afterward, I put an LS1 intake on it.
I've been a tourist in here for the last year, but decided to start a build thread. Anyway, this has been my project for the last 8 months, so here's the pics. |
01-19-2014, 01:02 AM | #2 |
Re: Powerslave's 66 SWB LS1 laid out with PB
More pics of the truck when I bought it
01-19-2014, 01:09 AM | #3 |
The first thing I did was shorten the frame. I jacked it up and welded 4 legs on the rear section of the frame that I was going to cut off so that it stayed straight with the rest of the frame. After I cut it, all I had to do was slide that section of the frame forward. I beveled the edges, welded it, made a fish mouth plate for the outside and boxed the inside.
01-19-2014, 01:11 AM | #4 |
more pics of the frame
01-19-2014, 01:12 AM | #5 |
Inside pic
01-19-2014, 01:17 AM | #6 |
If I would've known how far I'd end up going with the truck, I would've pulled the cab off by now, but my dumbass kept working around it. Anyway, I started with a Porterbuilt trailing arm cross member. Who would've known that I would've ended up buying every single part he makes for my truck, lol.
I had to take a pic of the crossmember because it's like taking a pic of artwork or great scenery. Tree huggers take pics of squirrels and waterfalls, and car guys take pics of nice welds and clean rides. |
01-19-2014, 01:03 AM | #7 |
I like the seat!
Looks like a few areas to spend some time redoing. Tuned in.
GOD BLESS AMERICA! |
01-19-2014, 01:19 AM | #8 |
01-19-2014, 01:22 AM | #9 |
I was about to cut my long bed sides down, dreading the amount of work that was ahead of me, when this swb trailer conversion came up on craigslist for $300. I dont think I could've been luckier on this one.
01-19-2014, 01:26 AM | #10 |
There's nothing worse that trying to get a couple of your buddies over at 11pm when you're ready to lift the bed onto the truck, so a friend of mine came up with this cool idea. He built this one-man-bed-lifter-upper weldment that is adjustable and fits right underneath the lip of the bed. Then you just use a cherry picker to lift it and move it around. Pretty slick.
01-19-2014, 01:27 AM | #11 |
It's always cool to see how many lugnuts you're actually tucking up into the fender
01-19-2014, 04:22 AM | #12 |
killer project so far man!!! ill be watching
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
01-19-2014, 02:08 PM | #13 |
chevy only
very nice!! and it was nice to meet ya Saturday!
CHEVY ONLY... Nothin Else ! |
01-19-2014, 04:23 PM | #14 |
I'm in for this one too! Nice truck
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
01-19-2014, 06:13 PM | #15 |
Cool truck and can't believe you found that short box for that price!
01-19-2014, 09:56 PM | #16 |
01-19-2014, 08:25 PM | #17 |
Smoking Fast Progress!!!
I'm in too!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
01-19-2014, 09:50 PM | #18 |
Thanks for all the comments, this site has been really helpful on my build
01-19-2014, 09:53 PM | #19 |
01-19-2014, 10:08 PM | #20 |
sweet project!
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana instagram - @esso_c10 @projectpawpaw |
01-19-2014, 10:37 PM | #21 |
pretty Kool build.. I'm watchin this one for sure...
If you ain't living life on the Edge.... Your taking up entirely to much space!!!! My 64 Stepper Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586792 |
01-19-2014, 11:56 PM | #22 |
Fitting this LS was a pain in the ass. Luckily I found a block at the swap meet for $80 with the cylinder wall blown out of it. I spent a lot of mock up time, mostly on the oil pan and headers. I ended up raising the engine about an in inch and moving it forward an inch or two. I had to raise it because the pan was either hitting the ground in the rear of the steering rack in the front. I even bought a low profile Moroso pan.
01-19-2014, 11:59 PM | #23 |
I bought a set of Corvette C5 headers, and that was a joke. They were way too wide to work with my frame, so I stayed with the factory truck manifolds. A couple of the LS forums say that those are pretty good exhaust manifolds. I did end up cutting off the drivers side flange and rotating it and changing the angle a little and welding it back on.
01-20-2014, 12:01 AM | #24 |
The reason I had to move the engine forward was because the 4L60e is sorta big and because I raised the engine, it was hitting the firewall/trans hump area, even with the high hump trans cover.
01-20-2014, 12:06 AM | #25 |
I finally got the engine/trans mocked up and got some new exhaust flanges to mate up my exhaust to the new manifolds. Now it was time for some sheet metal work.
I sandblasted the cab and found a crapload of bondo in the drivers side B pillar, so I found a donor pillar and swapped them out. Also welded the fuel filler as well. |
