Spindle bearing surface marred
When I removed my spindle needle bearings I resorted to a die grinder. Hastily I cut and marred the inside spindle surface a bit. It is in one section and a deep enough divot to feel. My new bearing pressed in tight, Is that anything I should worry about?
Re: Spindle bearing surface marred
Your talking the needle bearing cage on the inside of the spindle hub correct.
I don't think it would be a problem its just a support for the axle, not really load bearing.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
agreed. if it is just the stub shaft support needle bearings, you'll be fine. i assume its not drastically deep so as to affect the integrity of the spindle much.
Correct, just on the inside spindle itself, nothing to effect integrity and still a very tight fit. Thanks that puts me at ease!
