Old 01-19-2014, 06:10 PM   #1
1971 cheburban
Talking 12 bolt
How do you tell the difference between a "car 12 bolt" and a truck 12 bolt. I know I have a truck 12 bolt but I am just curious as to how you tell the difference between them without pulling the diff cover. The car was 8.5 inch ring gear, and the truck was 8-7/8 inch correct? Is there any tips or tricks to tell the diff? Hahahahaha get it
1971 cheburban is offline   Reply With Quote
Old 01-19-2014, 10:25 PM   #2
oklalawnboy
oklalawnboy's Avatar
Re: 12 bolt
I know the 73 up truck had a bigger pinion bearing. Not sure if that hold true for the pre 73
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 01-19-2014, 10:39 PM   #3
Fitz
Re: 12 bolt
The pics of the diff cover gasket say it all. Both 12 bolt diffs have an 8.875 in ring gear, but the housing is a different shape. The 8.875T is the truck, the 8.875P is the passenger car.
Fitz is offline   Reply With Quote
Old 01-19-2014, 10:51 PM   #4
mmiddle
mmiddle's Avatar
Re: 12 bolt
^^^^yep^^^^
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 01-20-2014, 05:10 PM   #5
Titus0
Titus0's Avatar
Re: 12 bolt
Ok to expand the question, what's the difference between a 67-68 12 bolt and the 69-72ones? I heard one is wider than the other? Does anyone know exact dimensions?
Titus0 is offline   Reply With Quote
Old 01-20-2014, 06:43 PM   #6
vidman
vidman's Avatar
Re: 12 bolt
I think the 67-70 axles were 55 1/2 inches wide and the 71-72 were 57 inches wide but not 100% sure.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 01-20-2014, 07:20 PM   #7
LONGHAIR
Re: 12 bolt
You have the 6lug and 5lug thing going on too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-20-2014, 08:07 PM   #8
Fitz
Re: 12 bolt
The width change came in 1970.
Old 01-21-2014, 07:46 AM   #9
Titus0
Titus0's Avatar
Re: 12 bolt
I thought the older axle was the longer one allowing for wider wheels in the back. Mine is a 12 bolt truck axle, but im not sure the year as the truck is kinda a frankenstein.. Im wanting to buy new wheels soon and i want 10" wide in the rear, but dont wanna have to deal with a clearance issue.. This is why i wondered the difference in axle widths,, It's a 5 bolt btw..
Old 01-21-2014, 10:22 AM   #10
Fitz
Re: 12 bolt
It is not that simple. The rear drum brakes came in two different configurations. 63-69 are narrower than 70-up by 1.5" BUT that is with 2" wide brakes and not 2.75" wide brakes,
The width differences are not because of different shoe width, the 2.75" wide shoe backing plates are deeper inset to make those axles same overall width from WMS to WMS as the 2" wide shoe axles.
All 70-up axle shafts and housings are same width regardless of shoe width,
the housing width is what changed, IE tube length, in 1970, then in 71 for 2wd's the wheel studs changed to 5 lug pattern with 1/2" studs, away from the 69 older 6 lug 7/16" studs pattern same for 2wd and 4x4
