Old 07-19-2003, 09:34 PM   #1
walker
walker's Avatar
HELP with PS pump mount on 350
I just swapped out my stock 327 for a 350 on my 67 chevy C10 and I can't mount the PS pump. The original mount was on the two bosses on the lower drivers side front of the engine. The 350 has the bosses but they are not drilled or tapped. Can I drill and tap these without striking water? Or is there an alterante method to mount my pump.
Also, the harmonic balancer is bigger on the 350, can I use the 327 balancer?
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 07-19-2003, 10:37 PM   #2
jhow66
jhow66's Avatar
Are you planing on using all the stuff off 327? If so go ahead and drill and tap. Should not hit water but if you do just use sealer on threads. As to the balancer use the pulleys off your 327 and bolt them to the 350--they will be in the same position.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-20-2003, 12:20 AM   #3
Andrew68c10
Me Too!
I have the same problem right now. I took my truck apart a year ago, and since then I forgot how it goes together. Maybe somebody could post a picture for us dummies?
Andrew68c10 is offline   Reply With Quote
