Old 01-20-2014, 08:19 AM   #1
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
shortening steering column
I have been searching since Thursday on how to shorten my column. I got everything loose and began to move it toward the dash. it might have gone an inch then nothing else. making sure I did the steps that were needing I crawled back under the dash and noticed that my neutral safety switch is hitting the firewall. I'm sure that someone on the forum has moved the nss into the engine compartment without having to modify the column at all. what did you guys do to shorten yours??
FRANKENSTEINC10 is offline   Reply With Quote
Old 01-20-2014, 08:42 AM   #2
Tinkermc
Re: shortening steering column
there was a member who lowered his down to the bowl and it looked great, if I remember correctley he gave a description and pic's, of course I can't recall his name.
Tinkermc is offline   Reply With Quote
Old 01-20-2014, 11:05 AM   #3
Evaded
Evaded's Avatar
Id also like a link to more info on this if someone has it? Thanks
Evaded
If I see a Zombie.. Im runnin it over with my Truck.
Evaded is offline   Reply With Quote
Old 01-20-2014, 12:09 PM   #4
JWPOORE
Not sure if this is what you were looking for:
http://67-72chevytrucks.com/vboard/s...67#post1625267
JWPOORE is offline   Reply With Quote
Old 01-20-2014, 12:12 PM   #5
Lou Boffa
Lou Boffa's Avatar
subscribed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 01-20-2014, 12:37 PM   #6
FRANKENSTEINC10
outstanding. thank you!! I will let you guys know how this goes. so far its been simple. if the nss were up about 5" on the column then i would havecompleted this yesterday in about an hour!
Old 01-20-2014, 07:54 PM   #7
nos487
nos487's Avatar
Let us know how it goes, does not look to bad. I could use the extra room myself.
nos487 is offline   Reply With Quote
Old 01-27-2014, 10:30 AM   #8
FRANKENSTEINC10
well fellas not a lot to update on this. I got the neutral safetry switch relocated to the engine bay with ease! the column is much shorter now over stock. I'm a big guy and I can finally extend my arms. my only problem has been getting the column back into the shaft!! my wife has been "helping" me but she's small and can't put a lot of force behind her. are there any tricks that you guys know of to make this easier? I will get pics up later today!
Old 01-27-2014, 11:20 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Pictures would help me. I can't quite figure out which shaft you mean, the main shaft that goes down through the column or the intermediate shaft that connects to the rag joint...
Here are a couple of threads that might help. They are actually about installing a van a tilt column but they might have some tips you can use.
http://67-72chevytrucks.com/vboard/s...d.php?t=133937
http://67-72chevytrucks.com/vboard/s...d.php?t=210459
LockDoc
Leon
Old 01-27-2014, 11:35 AM   #10
FRANKENSTEINC10
its where the main column connects to the intermediate shaft
Old 01-27-2014, 12:09 PM   #11
LockDoc
LockDoc's Avatar
You are talking about this joint then? It should slide together pretty easy if you spray a little penetrating oil on it. You have to make sure the bolt is not in it. It will not slide together if the bolt is in the clamp. Also, the slot in the lower piece (joint) has to be centered on the cutout in the upper shaft. You can also use a large screwdriver inserted into the slot in the joint to spread it apart a little bit, just go easy on it. You can see the slot in the second picture.
LockDoc
Leon
Old 01-28-2014, 03:16 AM   #12
sambudo
sambudo's Avatar
look forward to seeing your pictures. This is something i still need to do.
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 01-28-2014, 07:33 PM   #13
FRANKENSTEINC10
top pic is original location of course!
bottom pic is the new location. sorry for the filthy interior. haha its a work in progress. my dad bought this truck in 92 and I finally pried the keys away from him. go easy on me guys.
