Old 01-20-2014, 02:18 PM   #1
Gus350
68 C 10
Gus350's Avatar
Porterbuilt trailing arms
I have a set of the PB 3 inch drop TArms the u bolts had two nuts (one locking nut) and a washer on them how do you get both nuts on the u bolt. and what type of wrench are you using to tithen up the nut a standard 1 1/16 will not fit without grinding down. PB must be off today for the Holiday
Any suggestions would to get this buttoned up today.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 01-20-2014, 03:33 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt trailing arms
We are here and working... Just a long line of people to call back and email. If you left a voicemail and or a message we will return your call in the order in which it was received!
The plain steel nuts are just for mock-up and will not be used for final assembly. We use a 1 1/16 wrench to tighten them up.
You may want to mock it up with the plain steel nuts, as it might be necessary to trim some of the u-bolt so you have enough room to use the box end of the wrench and slide it out afterwards.
We modified one a little to work more easily. Took a grinder to the open end so it fit in better and gave us more range of motion.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-20-2014, 06:26 PM   #3
CYLFD
CYLFD's Avatar
I wrestled mine for awhile then took Nate's advise and trimmed some of the U bolt and it was cake after that.
Thanks again Nate for a great product.
CYLFD is offline   Reply With Quote
