Old 01-20-2014, 07:54 PM   #1
Rotaxx
Rotaxx's Avatar
Rescued Holmes 440
There's been a few good threads about tow and ramp trucks. I just rescued this 1970 C30 Holmes 440 tow truck. I think it's an original - the VIN tag has a GVW of 14000 pounds. It has a cool jump box under the hood - looks to be period correct, but I really don't know anything about it. The truck doesn't look like it was beat on or overworked - but that's pretty much the end of the good news. Nothing works at the moment. The engine doesn't run, and the trans seems to be locked up, and in gear - which makes for interesting loading and really interesting unloading.
Did we ever start up a tow truck club? Sure would like to hear what everyone thinks. Especially your thoughts the stuck 4 speed with PTO, which I really would like to get working again.
Thanks in advance.Name:  JAN2014 Tow Truck 001.jpg
Name:  JAN2014 Tow Truck 002.jpg
Name:  JAN2014 Tow Truck 007.jpg
1972 GMC Suburban 3/4 Ton
1970 C30 Holmes 440
Rotaxx is offline   Reply With Quote
Old 01-20-2014, 08:19 PM   #2
tommys72
tommys72's Avatar
Re: Rescued Holmes 440
I don't have any answers for you. .. but it's a cool truck
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-20-2014, 08:59 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Disconnect the driveline at the U-Joints. Then you can freewheel it onto the flatbed.
Old 01-20-2014, 09:13 PM   #4
Richardwa
Active Member
I had a 61 Chev with a froze 4 speed, a lot of penetrating oil around the base of the shifter and a few good solid smacks against the shifter got it to pop loose.
Seems the top end just dried out from sitting for 12 years or so
Nice truck, would like to find one like that around here!
Richardwa is offline   Reply With Quote
Old 01-20-2014, 09:20 PM   #5
Rotaxx
Rotaxx's Avatar
68Orange Sunshine,
That would have been the smart thing to do. I figured the wheels/brakes were dragging, so I winched it up onto the trailer. Then winched it back down off the trailer. About halfway down I thought to check the engine, and sure enough the belts and everything were turning as the truck was backing off.
So if the trans is stuck in a forward gear, and the truck was going backwards - i guess the engine was spinning in reverse direction?
Hope I didn't break anything.
1970 C30 Holmes 440
Old 01-20-2014, 09:25 PM   #6
Rotaxx
Rotaxx's Avatar
Richardwa,
Thanks for the tip, I will try that first, before anything more drastic (and expensive). Hope fully I can save the trans, I'm not looking forward to finding another one with a working PTO. Luckily I have a spare running 350 I can drop in to replace the non-runner if I can't bring it back to life.
1970 C30 Holmes 440
Old 01-20-2014, 09:56 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
Did you try pushing in the clutch?
WIDESIDE72 is offline   Reply With Quote
Old 01-20-2014, 10:02 PM   #8
Rotaxx
Rotaxx's Avatar
Good question. Yes - tried pushing in the clutch, and it did go in and felt like the right amount of resistance. Even with the clutch in, the shifter wouldn't move. I should add that when I first went to move the truck I tried to put it in neutral - shifter wouldn't budge.
1970 C30 Holmes 440
Old 01-20-2014, 10:10 PM   #9
Joesjunk
Joesjunk's Avatar
cool truck!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-21-2014, 01:27 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
Hmmm...Just trying to narrow it down to a stuck clutch or stuck trans... Would the truck "freewheel" when the clutch was pushed in? I have had a few stuck clutches in my day but never a stuck trans.
Old 01-21-2014, 11:27 PM   #11
1972RedNeck
1972RedNeck's Avatar
Just this spring I had a seized up SM420. You don't want to know how I got it loose though.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-22-2014, 01:05 AM   #12
70cst
70cst's Avatar
Hey Rotaxx ...
to the forums and from Ohio ...
as that is one ride
As far as "Tow" Truck Club ...
I will ask.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-21-2014, 01:10 AM   #13
allchevy58
allchevy58's Avatar
Drain transmission oil, take gear shifter and top of trans off and fill with diesel. Let it seat a couple of days and try to rotate. After you get it to free up, drain and refill with diesel one more time, let it seat a couple more days, rotating so all bearings and gears get lubricated. Flush with diesel till clean and refill with oil.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 01-21-2014, 08:14 AM   #14
hamjet
hamjet's Avatar
Might just be linkage problem. can you get it in neutral by moving the linkage on the tranny itself? OOPS, just noticed its a 4 speed, probably a top loader.....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-21-2014, 08:57 AM   #15
Rotaxx
Rotaxx's Avatar
Hamjet - I will check out the linkage, that's a good point. For some reason I was thinking this would be a top-loader trans like a 465.
WIDESIDE72 - I had the same thought. I was never able to get the truck to move with the clutch in, and couldn't decidedly rule that out as an issue. It's also possible that everything is locked up - clutch, linkage, and trans.
Does anyone know what kind of transmissions GM put in these tow trucks?
AllChevy58 - sounds like you've done this once or twice. Thanks for the recommendation. If all else fails, hopefully this will work.
1970 C30 Holmes 440
Old 01-21-2014, 09:18 AM   #16
BugzC10
BugzC10's Avatar
I would Drop the drive shaft to move it around. If you can get the nuts.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-21-2014, 01:55 PM   #17
WIDESIDE72
WIDESIDE72's Avatar
A one ton had an sm420 til mid 70's i believe then sm465. Whatever the case it is a top loader worh no external linkage like a GM car/ light truck trans.
Old 01-21-2014, 03:39 PM   #18
'68OrangeSunshine
'68 was the first year for the SM465 on the main lines. Perhaps, since they probably still had a bunch, they might've put the lower-geared 420s in the bigger rigs [C/30s]. I heard GMC and the Canadian lines used the 420s past '68. But usually 1968 is the model year for the transmission design change.
Not calling anyone a liar.
Old 01-21-2014, 05:44 PM   #19
Rotaxx
Rotaxx's Avatar
Well at least that's good news - if the trans is toast and it's a sm465, I have a spare that I know is good.
Hopefully the PTO survived. I'd like to get everything working again, just as it was originally.
1970 C30 Holmes 440
Old 01-21-2014, 10:43 AM   #20
Welcome to the tow truck club!...from a former owner
Pull the PTO and have a look-see. What position do you think the shifter is in? Could be an issue with the PTO,especially if it seems to be in neutral position. It could be some bonehead put it in (or tried) gear with PTO engaged.
Old 01-21-2014, 01:52 PM   #21
WIDESIDE72
WIDESIDE72's Avatar
If the engine wont move independently with the clutch pedal pushed in then you have a stuck clutch.
Old 01-22-2014, 01:42 AM   #22
frank69
I would be interested in a tow truck club I've got a 71 with a 440 just painted the bed and boom last week, getting ready to paint cab should be done in about a month i'll post some pics if I ever figure out how to do it
frank69 is offline   Reply With Quote
Old 01-22-2014, 02:07 AM   #23
70cst
70cst's Avatar
Thanks in advance.Attachment 1203222
Attachment 1203223
Attachment 1203225
Heavy Haulers .... there seems to be various threads on Tow Trucks there ...
Old 01-22-2014, 03:28 AM   #24
elf w/capital T
damn! thats sweet!!!!
elf w/capital T is offline   Reply With Quote
Old 01-22-2014, 07:53 AM   #25
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Nice score!
I'm all up for a tow truck club.
Got mine done this past fall after a 3 year back breaking restoration. See my build thread if you need any inspiration:
http://67-72chevytrucks.com/vboard/s...d.php?t=448256
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
