Old 01-23-2014, 10:54 AM   #1
stepsider
stepsider's Avatar
Power steering flush
My power steering works but doesn't feel right. I checked the fluid & it is dirty looking & has a rusty tint to it. I want to change or flush it. HOW that my question.
stepsider is offline   Reply With Quote
Old 01-23-2014, 11:02 AM   #2
Eddie H.
Eddie H.'s Avatar
Re: Power steering flush
Take the return hose to the reservoir off, run it into a bucket, and start the engine for a minute or so until it pumps all the old fluid out. Turn the steering wheel lock to lock to push out the remaining fluid in the gear box, then refill with fresh fluid and bleed the air out.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-30-2016, 08:45 PM   #3
DipStick82
How does one "bleed the air out" during this process? I'm about to flush mine also.
thanks!
DipStick82 is offline   Reply With Quote
Old 01-30-2016, 09:35 PM   #4
firedemon
after you flush the old fluid you can put a fuel filter on the return side to catch any extra crap that don't come out you would be surprised at the crap it will catch change the filter once or twice it will clog and starve the pump and squeal but shouldn't hurt as long as you don't let it squeal for too long
firedemon is offline   Reply With Quote
Old 01-30-2016, 09:40 PM   #5
DipStick82
ok. still confused at how i get the air out of the system though.
Old 01-30-2016, 09:46 PM   #6
firedemon
keep turning lock to lock sometimes you have to drive it a while it will bleed the air to the pump and recheck the fluid level
Old 01-30-2016, 10:04 PM   #7
swamp rat
swamp rat's Avatar
Put the hose back on the pump and fill the reservoir, fire it up and crank side to side, check, fill, repeat.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-30-2016, 10:15 PM   #8
DipStick82
How much fluid should I buy?
Old 01-31-2016, 01:39 AM   #9
BCOWANWHEELS
I hook a gallon jug of new p/s fluid to pump via return line so pump dont run dry, mount it higher than pump. Then take return line from p/s box and run it into some kind of catch let new circulate the do lock to lock a few times. Rehookup return line and your done. I also install a return line filter.
Bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
