Old 01-23-2014, 09:45 PM   #1
69SCSS
69SCSS's Avatar
Quick Blazer tank install question.
I installed my tank where I thought it should go, everything lined up perfect and if fit great, until I dropped the bed on the frame this weekend. The 3rd bed support back hits the top of the tank and the filler neck! Do you have to trim that support to fit the tank? Unless I turn the whole tank around and move it as far back as I can, I don't see how this is supposed to fit. Anyone have any pics from underside? My filler neck points straight at the hole for the bed mount on that support.
Any thoughts? Every picture I've seen as I've done a search shows me I have the tank mounted correctly. My bed is shortened, but it looks like the support is in the correct place.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 01-23-2014, 10:08 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Quick Blazer tank install question.
It's correct. You have to cut the support. My truck is a stepside and I don't use my bed, I completely removed mine.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-23-2014, 10:10 PM   #3
oldschool18
oldschool18's Avatar
my tank is in the same place and I saw a thread where you have to cut the support. don't remember what thread I saw it in thou.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 01-23-2014, 10:20 PM   #4
69SCSS
69SCSS's Avatar
I looked all over the place and couldn't find a thread that showed anything like that... even found the FAQ thread about the tank install. So that means you lose an entire support, so only 3 supports for the bed? Doesn't that weaken the bed floor between the 2nd and 4th support?
My 68 SWB
Al Silveira Music
Old 01-24-2014, 10:28 AM   #5
67ChevyRedneck
No, you don't lose an entire support. I removed my support because I don't use my bed and I have treated deck boards as a floor.
Yes, the floor is flimsy. My truck hasn't had more than a few bags of trash in the bed in the past 15+ years.
I've seen lots of people cut the support. Some weld back a plate, some don't.
You should only have to cut inside the frame rails.
Here's an install with some pics classic trucks did. Cutting the cross member pics are on "page 2."
http://www.customclassictrucks.com/t...lmc_truck.html
Jesse James
Project "On a Dime"
Old 01-24-2014, 01:37 AM   #6
oldschool18
well you don't lose the entire support......I haven't got that far yet in my build. I was going to cut out what I need to and rebuild it somehow, sorry I cant help out anymore.
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Old 01-24-2014, 01:41 AM   #7
69SCSS
69SCSS's Avatar
My filler is hitting the support, so there wouldn't be much left of the support on the driver's side. I could keep the support from the frame out on the passenger side and use the mount bolt there... but the driver's side would be tough. I'll have to see how I can save as much as I can of it.
anyone have a pic?
My 68 SWB
Al Silveira Music
Old 01-24-2014, 10:12 AM   #8
hugger6933
I think the answer is gonna be after the clearance is gained that you need, you may have to box that support in to give it back some muscle. I think that would be just fine if you were to box in the rail there it would be plenty stiff again. A whole lot better than not having one at all or one that is trimed way down. Jim
hugger6933 is offline   Reply With Quote
Old 01-24-2014, 09:54 PM   #9
swamp rat
swamp rat's Avatar
Is it possible to relocate a frame cross member to shift the tank for or aft?? I recalled reading somewhere about removing a cross member and flipping it 180 end for end and reinstalling it to gain room? Just a thought.
What about relocating the support? you's have to fill in the old bolt square holes and re drill and file 2 new ones if the carriage bolts go thru them.
Just a couple ideas...
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-24-2014, 10:06 PM   #10
69SCSS
69SCSS's Avatar
Actually that's what I am planning on doing. I'm going to keep the mounting in the same spot, but move the support out of the way of the tank. Probably going to move it forward towards the cab. Not sure yet, gotta do some measuring. For now the support is coming out, and when I get to finishing the bed I'll figure that out. Glad I wasn't doing anything wrong, I don't want to us the in cab tank!!
My 68 SWB
Al Silveira Music
Old 01-24-2014, 11:48 PM   #11
Rust_phoenix
Rust_phoenix's Avatar
I cut the support down on the underside of the bed, and removed the front brace and also moved the tank as far back as I could, my truck is a 4x4 and it clears the support just fine now, the tank is a poly replacement and I know others have had problems with the metal tanks neck not being able to line up, but I'm betting if you can move yours back it will clear, not sure why the search didn't help a lot of others have done this, anyway here are a few pics.
My build: Project "Lazarus" 8.1 Vortec and Allison in a 72 swb k10
http://67-72chevytrucks.com/vboard/s...d.php?t=555878
Rust_phoenix is offline   Reply With Quote
Old 01-24-2014, 11:51 PM   #12
Rust_phoenix
here are a couple more showing the tank and neck position
Old 01-24-2014, 11:56 PM   #13
69SCSS
69SCSS's Avatar
If I can slide the tank back that far I should probably be able to get the filler on that side. Would save the trouble of adding another support. Thanks for the pics!
My 68 SWB
Al Silveira Music
Old 01-25-2014, 12:26 AM   #14
swamp rat
swamp rat's Avatar
My Boyd's tank sits below the frame rails on my K20, maybe a different talk would be a better option? Just a thought. For reference i also have a long bed so i know my situation is different than a short bed.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-25-2014, 12:29 AM   #15
69SCSS
69SCSS's Avatar
yea long beds are different. The higher up you can get the tank the better, I would guess that would be even more important in a 4x4 for ground clearance. When it was installed right my tank hung down about the same height as the bottom of the bedside. I wouldn't want it to be any lower, personally, especially with a 5" drop in the back.
My 68 SWB
Al Silveira Music
Old 01-25-2014, 03:31 AM   #16
First c10
First c10's Avatar
Not sure if you can see what we had to do. It was lowered so we had to cut a relief in to got the lowered leaf springs and shackles some clearance.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-25-2014, 03:35 AM   #17
First c10
First c10's Avatar
Another picture!
GO GO!!!
Old 01-26-2014, 12:39 AM   #18
Hugh Mongus
There's an episode of Trucks where they installed that gas tank and they show how to modify the bed. They also installed a gas filler door behind the side marker. I though tit was worth watching.
http://www.powerblocktv.com/episodes...ls-engine-swap
hope it helps
Hugh Mongus is offline   Reply With Quote
Old 01-26-2014, 05:10 PM   #19
muckyp
muckyp's Avatar
Hey Rust_Phoenix, how did you do your fuel filler?
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 01-26-2014, 08:00 PM   #20
Rust_phoenix
I welded in a filler door and fuel fill neck from a 1991 S10 pickup page 1 of my build thread has a few pics, I got the idea from others here on the site and gave it a try.
Old 01-26-2014, 09:31 PM   #21
69SCSS
69SCSS's Avatar
I already have my Suburban filler, but I'm going to do something very similar to what you have, that looks great. Thanks for sharing that!
My 68 SWB
Al Silveira Music
Old 01-26-2014, 06:29 PM   #22
69SCSS
69SCSS's Avatar
hope it helps
Awesome, thanks!
My 68 SWB
Al Silveira Music
Old 01-27-2014, 12:16 AM   #23
Rust_phoenix
You are welcome, glad to help.
Old 01-27-2014, 02:25 AM   #24
First c10
First c10's Avatar
This is what I did for a filler neck
GO GO!!!
Old 01-27-2014, 02:27 AM   #25
First c10
First c10's Avatar
This is how I fill it.
GO GO!!!
