Good donor?
I found this little gem and I am curious if it would make for a good donor for my 1963 Chevy stepside long bed this frame is off of a 1974 Chevy Crew Cab Dually Two Wheel Drive Truck. I was thinking I could hijack the brakes and maybe looks like there a power steering setup on there too. They are wanting 300 for this.
![]() Join Date: Sep 2006
Re: Good donor?
what are you using it on? Won't work for a 1/2 ton.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Re: Good donor?
Not even the front rotors and the front part? Or the power steering box?
Re: Good donor?
Not worth $300 for a steering box and some rotors. I would not use it for a 1/2 ton since it is like a 1 ton.
Re: Good donor?
Well I was not talking just the rotors but instead the whole setup. Rotors calipers etc.i am trying to avoid paying the 1 k plus online for the kits
Re: Good donor?
There are ways to do it if you piece it together yourself. Try looking on Craigslist for a 1/2 ton donor.
60-66 Nut
Re: Good donor?
About the only thing on that frame that would be usable on a 1/2 ton is the steering box. The rest is all 1 ton 8 lug.
There is absolutely no reason to have to pay $1k for a suspension and brake upgrade. There ought to be plenty of '73+ C10 pickups and Suburbans in your area that you can get for parts.
Re: Good donor?
I used an '81. I paid $75.00 for it.
Lots of good info here. This will help you find a donor. http://67-72chevytrucks.com/vboard/s...d.php?t=367260 http://67-72chevytrucks.com/vboard/s...d.php?t=263983 This is what I did. http://67-72chevytrucks.com/vboard/s...d.php?t=453346
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
