Old 01-26-2014, 10:25 PM   #1
Thebrownturd
vent window question
I would like to hear your guys opinions on the vent window seals. Where can I get some seals that will fit really good and does anyone have any advice to putting in the new felt division bar liner so that it looks good.
Thebrownturd is offline   Reply With Quote
Old 01-26-2014, 10:36 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: vent window question
I can't help on the seals but the division bar was pretty easy to get to look right.I drilled the riverts from the old one.Then I matched the hole to the new one.I had to drill them a slightly larger size because I couldn't find the smaller rivets.I used pop rivets but the anvil of the rivet gun wouldn't fit into the division bar.I cut a short piece of copper tubing and put it over the rod of the rivet then put the rivet into the division bar and got it as tight as I could.Then pumped the handle on the rivet gun.The division bar has stayed put for over ten years.I also recommend using some lube(I use silicone like for foosball bars) on the felt in the channel.It seems to help the felt smooth out and work in.Make sure you have the division bar tight in the channel on every rivet.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-27-2014, 12:21 AM   #3
Thebrownturd
Thanks I definitely need to get a rivet gun or something.
Old 01-27-2014, 02:33 AM   #4
leddzepp
Moderator
leddzepp's Avatar
I did this as well, except I used a bench grinder to shave down the anvil so it would fit in the channel
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-27-2014, 12:24 AM   #5
70LonghornCST
Moderator
70LonghornCST's Avatar
I used Precision brand on my rebuild. They worked well.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-27-2014, 02:27 AM   #6
leddzepp
Moderator
leddzepp's Avatar
X2. They fit like a glove. GMCPaul and Classicheartbeat carry them.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-27-2014, 03:50 PM   #7
kcsa75
kcsa75's Avatar
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 01-27-2014, 10:51 AM   #8
PanelDeland
Also make absolutely sure you have the rivet seated all the way to the bottom of the channel and that the head is flat against the bottom of said channel.
