Big Cowl hood
Does anyone know where I can buy a 4" or 6" cowl hood for my 1968 4x4 chevy? I'm hoping to fit a weiand 250-256 supercharger.
Re: Big Cowl hood
You can make one... Heard too many horror stories about after market for these. No factory dies to duplicate. Out of square, etc. bloody night mare. I made mine. Took some time but fits great. Go slow with the welding... Easy to warp if you do. Wasn't sure on the carb(s) setup... And still aren't. Wanted the clearance in case I got crazy.(mines a 4")
Re: Big Cowl hood
they are pricey but you can check into Harwood
I have a four inch fiberglass hood on my wifes 72 pick up came with the truck when we bought it |
Re: Big Cowl hood
It's so easy save a bushel basket of money and make your own.
Re: Big Cowl hood
Auto metal direct sells a 4 inch scoop made from metal
Re: Big Cowl hood
Thank you all. I will check harwood and auto metal direct. What did you guys use to make your own? What did you use for cowl hump?
Re: Big Cowl hood
I used the 2 inch from auto metal direct
Re: Big Cowl hood
Does anyone know how big of a cowl it would take to cover a BBC with a 250-256 weiand supercharger?
Re: Big Cowl hood
hello, i got my 4" cowl from unlimited, covers a tunnel ram
#10 | |
Re: Big Cowl hood
4-71/6-71 would clear a stock hood. . Mine has a 454 and must be a foot between the top of the carb and the bottom of the stock hood. I do have a fiberglass cowl hood for it, but it's not on yet though.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
Southern Nevada Coal Roller
Re: Big Cowl hood
71chevyowner.
Do you have a part number for the 4"? I been looking and can't find it. Also did you cut out under the hood or just add for looks. Just wondering about strength of the hood if you cut it out. Any pics? Chris
Chris 72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo. 36 Chevy P/U rat rod project. 4bta cummins ![]() |
