01-28-2014, 11:24 PM | #1 |
How do I get belt buckle apart?
I'm trying to get my 67 seat belt buckle apart, can anyone tell me how to get hinge pin and adjustment bar/ roller out?
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
01-28-2014, 11:39 PM | #2 |
Re: How do I get belt buckle apart?
The hinge pin must press out one way or the other but not sure which way.
The adjustment bar I have no idea.
01-28-2014, 11:43 PM | #3 |
Moderator
Here you go. Click this LINK. I wrote this up for those of us like you who needed to accomplish this seemingly impossible task. Have fun!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
01-28-2014, 11:46 PM | #4 |
Moderator
Ok, I just realized that the pictures on that post are gone. I'll have to retake them and repost. I'll try to get them done ASAP.
Sorry for the tease Richard
01-28-2014, 11:48 PM | #5 |
Moderator
Now that I look back at your original post, I don't think my write up will help. Mine was for the plastic cover type, which is different than the '67 belts. Sorry.
01-28-2014, 11:59 PM | #6 |
Ya, I found that post or at least one like it for 68-72's, but can't find anything on 67's. I'm sure I could get it apart with a little force, but putting it back together when painted & re-chromed might not work out too well.
01-29-2014, 06:36 PM | #7 |
I wouldn't swear to it, but I'd be willing to bet the metal casing is bent in a press after the unit is assembled to prevent the mechanism from coming apart. NTSB regulations and whatnot. You could build a jig on a car jack to open it a bit and then press the sides back together, but you'd have to retemper the steel as bending it back and forth will most like cause fatigue.
Good luck. |
01-29-2014, 07:35 PM | #8 |
That's kinda what I was thinking I would have to do. I'm not sure i could get it bent back without cracking or at least scratching the chrome not to mention a freshly painted top.
01-29-2014, 08:06 PM | #9 |
You could try a bench vice with a thick piece of leather on the sides unless you have one without teeth. It'll probably try to come shooting out, though. Just buff out the scratches when you're done so long as it's not gouged... If that's how GM did it 40 years ago, it should work fine
01-31-2014, 11:06 PM | #10 |
I got it apart 1 belt ready for paint & chrome.
02-02-2014, 07:41 PM | #11 |
Painted the buckles today,I hope I can get them back together without scratching them
02-02-2014, 07:56 PM | #12 |
Those look great! Did you have to tweek it a bit to get them out?
02-02-2014, 08:09 PM | #13 |
Thanks, I didn't actually have to tweak the chrome base I just pushed the pin out a little from the side with the wedge in it the I pulled the buckle up (with a little force) then drove the pin back the other way. Putting it back together without scratching it will be more of a challenge. The adjustment pin I filed the corner VERY slightly on one side then drove it out with a punch. That will make sense when your trying to get one apart.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 Last edited by gonnuts; 02-02-2014 at 09:09 PM. |
03-23-2014, 02:19 PM | #14 |
I got buckles back from getting re-chromed. Got 1 back together, scratched the other So I'll repaint it & try again.
03-23-2014, 04:13 PM | #15 |
They're looking real sharp.
03-23-2014, 07:04 PM | #16 |
03-23-2014, 09:41 PM | #17 |
Those do look good...
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
05-06-2014, 10:35 PM | #18 |
Finally got my belts done with retractors
Attachment 1251080
05-06-2014, 10:49 PM | #19 |
