"Junkyard Dog"
![]() Join Date: Jan 2008
Parting out 72 C20 350 AT a few nice parts
Just finished this one its a 72 Chevy C20 with a 350, TH350, and was a leaf spring D60. A decent old truck with a few nice parts. Most metal parts are hot tanked and acid dipping available upon request with no charge. Paypal fine with no fees or MO. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
"Junkyard Dog"
Re: Parting out 72 C20 350 AT a few nice parts
pics
"Junkyard Dog"
Pic 1
AT shift linkage 40.00 crank pulley for fan/alt, single groove. 10.00 Custom/20 emblems very nice chrome not pitted, needs black repainted 12.50 each Deluxe emblems needs black repainted 5.00 each 350 emblems nice needs black repainted original battery cables 5.00 each 2wd P/S gear 60.00 AT trany coolers 8.00 each E-brake ratchet control been hot tanked. 25.00 Hood latch 15.00 original C20/K20 rear cab bolts nice 5.00 4 core rad mounts, uppers-lowers-cushions, two cushions not in pic. 35.00 Hood hinge RH nice and tight been tanked. 25.00 Hood hinge LH some play still worked fine. 10.00 Seat tracks with cable, spring and bolts 40.00 Pic 2 Outside door handles very nice IMO 25.00 each 45.00 pair Inside vents nice seals paint came off when cleaned. 12.50 each Vent pull rods with knobs. one knob not in pic. been tanked 7.00 each air cleaner spacer with hose been tanked 15.00 Tailgate hardware on box 4 pieces with bolts 25.00 washer hose set 12.50 tail light lens original nice 10.00 each Front turn lens 71-72 nice 10.00 original wiper arms 10.00 each original wiper arm with trico blade 12.50 fender/core support triangles nice 7.00 each heater control good housing and arms nice unit 45.00 Pic 3 TH350 dipstick and tube been tanked nice 25.00 TH350 Vac modulater line tanked nice 15.00 71-72 front bumper brackets 15.00 each 350 Q-jet fuel line nice ends/no kinks been tanked 15.00 steering rag joint nice 22.50 steering intermedate shaft nice 25.00 72 Q-jet intake tanked, acid dipped, and media blasted very nice 65.00 Other items in pics Deluxe black door panels RH has a couple scratches very minor. I took pics but they won't show up. Very nice panels. 125.00 Rear box splash shields acid dipped and media blasted. 25.00 each Black steering wheel. 3 cracks, one at 12:00, 9:00 and bottom center hub. very nice driver. With center cap 115.00 LH Box Patch panels 25.00 each RH fender rear patch panel 20.00 Front lower control arms 25.00 each Front upper control arms 20.00 each Spindles 25.00 each Rotor stone shields no rust 15.00 each draglink 71-72 25.00 SB engine stands 25.00
Moderator
![]() Join Date: Jun 2008
Hi Tom! Nice sounding truck. Please get some prices up per forum rules. Great deal with the acid dipping offer!
Good luck, Richard
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#5 | |
"Junkyard Dog"
"Junkyard Dog"
more pics
"Junkyard Dog"
Pic 1
Pic 2 Pic 3
Moderator
![]() -Richard
![]() Join Date: Apr 2012
Tom,http://67-72chevytrucks.com/vboard/clear.gif
Could I get a total on the following to 84043? 350 Q-jet fuel line nice ends/no kinks been tanked 15.00 Hood hinge RH nice and tight been tanked. 25.00 original battery cables 5.00 each steering rag joint nice 22.50 TH350 Vac modulater line tanked nice 15.00 AT trany coolers 8.00 each TH350 dipstick and tube been tanked nice 25.00 Thanks, Paul |
![]() Join Date: Apr 2011
I will take the outside door handles and what is the cond of the tail light harness? prices shipped? thanks.
Just like to part out trucks!!
Tom, how is the drivers side exhaust manifold, its straight down isn't it and for a 72? I'm needing one for the blazer. I like your acid dipping, cleans the parts up great. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
G87 Dana 60 Power Lok rear ? what gears ? and will you sell just the carrier assembly ? ..shipping whole rears are normally game-breakers.
interested in power steering is that gear and pump? is this direct bolt on for 68? I know the brackets are different. I also need the right side tailgate hinge. Thanks
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
"Junkyard Dog"
Just getting off work and have a meeting till about 8:00. I'll get back to all of you when I get home. Thanks, Tom
#15 |
how much for brake booster master cylinder and proposional valve shipped to 39702
#16 |
"Junkyard Dog"
bluek5 Paul, 150.00 shipped
REEDS 72, The tail lamp harness is very nice. I was going to keep it for one of my builds but I'll sell it as I have more. 15.00 for it 50.00 for the handles and 13.00 shipping. 78.00 shipped for all of it. Randy, Are you running a heat riser? These were suppose to be in my 72 K20 thread as they were off that truck. The bottom one in the pic would correct for the blazer. The top one originally had a alt mount that was cut off to fit a 69-72. 50.00 plus shipping. 15.00 shipping? viking427, The rearend was sold months ago. I do have gears 3.54, 3.73, and 4.10. 50.00 for any ratio. I have D60 "trac lok's" for 100.00, no "power lok's" right now. sambudo, No it for the gear only and yes correct for a 68. 7.50 for the TG hinge plus shipping. bertvert72, Let me know your addy for shipping cost. sflem61, 65.00 for assembly and 22.00 shipping
#17 |
Tom, yes on the heat riser, I need the drivers side and also the throttle cable from other thread, 66512. Thanks no rush, Randy
#18 |
Tom,
Sounds good, send me a PM with payment information. Thanks, Paul |
#19 |
I will take the outside door handels and the rear tail light harness are the handels 50.00 or 45.00? pm me pp info thanks Reed.
#20 |
Tail light chrome trim?
#21 |
please send me payment info on brake booster
#22 |
"Junkyard Dog"
Randy, shipping is 22.90 13lbs via UPS. The truck in the 4x4 thread didn't have one. Sold it a long time ago. I can get one off for you though. Got 3 trucks with them.
bluek5 Paul, PM sent Reed your PM box is FULL. Just PM me after clear some room. Vova, Both sides? I have some off I'll look at them. sflem61, PM sent
#23 |
![]() Join Date: May 2003
Tom
I'll take both the rear splash shields along with a nice ds door latch control we already spoke about. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#24 |
#25 |
didn't see a price for the automatic steering column, if it is available price with shipping to 34668 please.
