01-29-2014, 10:16 AM | #1 |
custom rear trailing arms
Has anyone on the forum fabricated their own rear trailing arms? Been tossing the idea around
01-29-2014, 11:18 AM | #2 |
Re: custom rear trailing arms
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
01-29-2014, 11:22 AM | #3 |
Awesome, thanks! Was thinking about building a set with some built in drop
01-29-2014, 07:05 PM | #4 |
Old member
Other than just for the cool factor that you did them your self, there are several vendor on here who make them just for our trucks. Even with the blocks attached.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-29-2014, 08:00 PM | #5 |
I just prefer to make my own stuff
01-29-2014, 11:21 AM | #6 |
I have been considering it only because I have a friend with a heavy fabrication shop and the right equipment to drill tap and thread the forward end to use Heim joints and the heavy press to achieve the proper aft bend and correct welds to hold it all together and make them track correctly .I will have to call him today and check on the correct materials and how many cases of beer it will take !
01-29-2014, 07:29 PM | #7 |
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
