Old 01-29-2014, 06:43 PM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
55-1 Floor Replacement Absolute Sheetmetal
I have a truck cab in the shop now that needs a floor and toe panels along with some kick panel work and some door work. The floor kit is an Absolute Sheet Metal 751002 for a stock firewall. The kit consists of the toe boards, toe board extensions, floor boards. front cab supports, master cylinder door, transmission tunnel, a floor brace, some screws and a set of alignment brackets. I haven't used this kit before and it was purchased by the customer but so far the kit looks to be of very good quality the instructions appear to be good, pictures are a little washed out but still view-able. We are starting this on Friday and will post start to finish and follow the directions in the paperwork so you can see for yourself if you want to tackle this type of project. This is a board members cab from Lufkin Tx so if it looks familiar that's where you saw it.
Old 01-29-2014, 06:45 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 55-1 Floor Replacement Absolute Sheetmetal
Here are some floor pics. Its very solid for an East Texas truck from the 50's
Old 01-29-2014, 07:01 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking forward to watching this.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-29-2014, 09:57 PM   #4
918733
Man that looks just like my cab, oh wait that is my cab, this is exciting. And I get to watch, Dave it was nice meeting you guys today.
918733 is offline   Reply With Quote
Old 01-29-2014, 10:06 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Good to meet you as well and thank you for the opportunity to work on your truck. Check your email I sent some questions to you.
Old 01-30-2014, 03:58 PM   #6
gale
I'm also in Houston and will be replacing the floor in my '54 3100. Currently the cab is stripped of everything and mounted on a rotisserie I fabricated. My plan is to go back with flat 16 ga. sheet metal.
Gale Gorman
'54 3100
'67 C20 stepside
gale is offline   Reply With Quote
Old 01-30-2014, 04:07 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Your welcome to stop by Saturday and see what your in for. We should have it all cut out by then and starting the fit up for the new panels.
Old 01-30-2014, 04:59 PM   #8
OrrieG
OrrieG's Avatar
This should be a good one for the tech article section.
Old 01-30-2014, 08:23 PM   #9
gale
What is a good time for you and I'll show up.
Gale Gorman
'54 3100
'67 C20 stepside
Old 01-30-2014, 08:41 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
about 10:30 11 ish that way well be setup to work. Saturdays we start a little late
its at 221 baker rd 77094 here is a map of where we are in the complex at the red A
Old 01-31-2014, 09:37 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
We have the cab mounted on a frame section, You can drop the front bolts in for alignment and on the rear you can either use the stock mounts bolted up or use 3/4" spacers placed between the frame rail and the rear cab support. This is the recommended height for the rear of the cab from the assembly manual.
The first thing we did after the cab was secured was weld in the braces supplied in the kit, they stabilize the rocker and pillar area so when you remove the the cab mounts the doors will still line up. We then laid the pans in place and marked the perimeter and cut 2" to the inside of that mark and removed the old floor and toe panels.
If you don't have the tool pictured you need one. Its made by Steck and its for busting seams and spot welds. Tool number 20015 in the picture. It makes this job so much easier. The area under the right side cab support needs repair and it will require different bracing because we have to remove the supplied brace when we fix that spot.
Old 01-31-2014, 09:45 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
We also have the new kick panel patches made and rough fitted. The original supports are going to be reused. The kit does come with new supports but if your reusing the stock foot brake the pedal brackets won't bolt up to the new support without reworking it. We have the rust treatment started.
Old 01-31-2014, 10:19 PM   #13
gale
I look forward to seeing it in person tomorrow. My '54 isn't that rusty.
Gale Gorman
'54 3100
'67 C20 stepside
Old 01-31-2014, 11:02 PM   #14
918733
I have to say you guys are really moving along can't wait to get it back
Old 02-01-2014, 12:20 AM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
Two guys make short work of taking it apart, its the making patches and fitting them and making it all look right that takes longer.
Old 02-01-2014, 12:33 AM   #16
918733
I have full confidence in you guys
Old 02-01-2014, 05:39 PM   #17
dwcsr
Hollister Road Co.
dwcsr's Avatar
We have the left side kick panel repaired and the toe board support in place. The toe board support is welded in and left as you see it. Absolute says to lay the toe board on top and do a lap weld on each side. Next I set the rear floor support in place and laid the floor pan and toe board in and tacked the toe to the firewall. When it comes time to weld you will run a bead down the toe support outside and inside. across the bottom inside and out and up on the top inside and out. The floor is welded in with a series or roset welds across the back and on the floor support.
Old 02-03-2014, 10:18 AM   #18
918733
Super Cool and Thanks for putting up the pics
Old 02-03-2014, 08:06 PM   #19
dwcsr
Hollister Road Co.
dwcsr's Avatar
We have the right side kick panel and wheel house repaired, the rot was a little more that we first thought but still plenty of good metal to weld to, just need to clean up the welds. Trimmed up the firewall edge and repaired a place at the column hole that was chewed up. I'm thinking the next post should show a completed floor and we can move onto the other issues.
Old 02-03-2014, 08:46 PM   #20
918733
Heck yeah
Old 02-05-2014, 09:37 PM   #21
dwcsr
Hollister Road Co.
dwcsr's Avatar
The floor is in and the toe boards tacked in place awaiting final welding. We did have some issues fitting the tunnel to the engine recess due to previous modifications to get clearance for a distributor. We also did have some minor trimming on the toe boards around the recess but not much. The kit appears to be designed to allow you to move the panels to some degree and because no two cab are alike you do need some fudge room. Once all the panels are welded we will weld down the tunnel.
Next is the area under the cab support on the right side that is rotted near the bottom but looks OK at the support. We needed to have the floors all done before repairing that area because we need to remove it from the frame mount to do that repair. That area helps with the stability of the door pillar. As it is now when the door is opened and pushed against the stop that area flexes about a 1/4" so we need that weak metal replaced.
Old 02-05-2014, 10:33 PM   #22
918733
Looking like a truck again
Old 02-06-2014, 12:52 AM   #23
av8tr33337
av8tr33337's Avatar
Thanks for posting the process. This is really going to help a lot of us.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 02-06-2014, 12:58 AM   #24
oldman3
oldman3's Avatar
Floor looks great, and nice job on the install. Looks very similar to the kit I installed in mine about 12 years ago, here's a copy pics (hope you don't mind)...Jim
oldman3 is offline   Reply With Quote
Old 02-06-2014, 01:08 AM   #25
dwcsr
Hollister Road Co.
dwcsr's Avatar
Sure does look like the same kit. Same cuts and the tunnel is the same shape.
