01-29-2014, 06:54 PM | #1 |
Can I use 63 to 66 ball joints in 73 to 87 control arms
Hey guys long time watcher first time poster, will the 63 to 66 upper and lower ball joints work in the 73 to 87 control arms
Thanks! |
01-29-2014, 07:13 PM | #2 |
Re: Can I use 63 to 66 ball joints in 73 to 87 control arms
Yes.
01-29-2014, 07:24 PM | #3 |
67-72 parts collector,…
yep,... as long as both sets of a-arms are 1/2-ton.
3/4-ton lower a-arms have a larger balljoint hole.
01-29-2014, 07:42 PM | #4 |
Thanks for the response guys!! One more thing, I read that you have to use 73 to 87 ball joints if you use a 2 1/2 drop spindle is this true?
Thanks again guys! |
01-29-2014, 07:49 PM | #5 | |
Drop spindles can be purchased for the following years. 60-62 63-70 71-72 73-87
01-29-2014, 07:49 PM | #6 | |
Never Ending Projects
If you're buying used ones, make sure you know what years they are for before you buy ball joints. Good luck and welcome to the forum!
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-29-2014, 07:53 PM | #7 |
Watch out for your cornhole !
Not true. You have to use whatever ball joints fit your drop spindles. There are 63-70, 71-72, and 73-87 flavor of dropped spindles on the market.
Now, there is one dirty company that comes to mind that sells 73-87 drop spindles for early trucks and tells you that you need to swap your ball joints and steering linkage to 73-87 stuff to match. That's just ghetto of them and no longer the best option. That was the path before Early Classic started making true bolt on spindles for the earlier trucks, back when 73-87 drop spindles were the only ones made. Nowadays though, if you order spindles for 63-70 trucks, you can reuse all of your steering linkage and 63-70 ball joints and not have to swap everything over to late model stuff, saving real money in the long run.
01-29-2014, 07:54 PM | #8 |
Spindles also have to match the outer tie rods.
Don't create issues you don't need. It's really not that hard now that they make "year specific" drop spindles.
01-29-2014, 07:54 PM | #9 |
Damn, I'm a slow typist on this iPad. I got treed by two guys as I hunted and pecked my answer out.
01-29-2014, 07:56 PM | #10 |
Everyone is in agreement!
Ha. Too bad this info can be broadcast better. I've been saying this stuff for at least 10 years on here.
01-29-2014, 08:06 PM | #11 |
Thanks guys! I searched but only came up with conflicting responses but I knew it would be cleared up here
01-29-2014, 08:56 PM | #12 |
Ok one more question and I'll leave y'all alone lol can I run the 73 to 87 hubs on the 63 to 66 spindles?
Surely not because that would be to easy right? Lol |
01-29-2014, 09:10 PM | #13 | |
Can I run the 73-87 rotors on the 63-70 conversion drop spindles? YES. Just get the HD (heavy duty) version which are 1.25" wide. Actually 71-87 HD rotors will work.
